Question about Olevia LT42HVi 42 in. LCD Television
Remove base from tv?
I have mounted my 32inch Olevia lcd tv and I cant get the base to comew off, I have unscrewed it and it still wont come off.
How many screws did you remove? You should have eight, there are 2 screws along the bottom that are easy to miss. Make sure you check each hole with a flashlight just to make sure you got them all.
Posted on Jan 13, 2009
We are mounting the Television and would like to remove the base. How do is come apart
if you look at the rear of the set you will notice 8 screws, they should have arrows on the housing pointing at them. Have 2 people hold the display while you remove the screws. have them continue to hold it while you put the mounting plate on the rear of the TV. Below you will find links to the Mfrs.
Good Luck!
Sep 02, 2011 | Olevia 237T 37 in. LCD TV
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Stand wont come off grundig tv model gu19wdvd3 to mount it
Remove the three screws from the back of the stand.
Remove the four screws from the bottom of the stand.
Looking down at the bottom of the stand, push the four protuding clips inwards (not easy - you may need to gently ease them with a small screwdriver)
This unclips the oval base and allows you to unscrew the remaining screw inside the stem of the base
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
How to remove Olevia 437 base???
I know its been awhile but you have to lift on base while unscrewing... Couple of seriously long bolts that eventually stop when unscrewing.. lift and put pressure to continue unscrewing
Dec 18, 2008 | Televison & Video
Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Nov 14, 2008 | Coby TF-TV2608 26 in. LCD Television
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Most Protron and Ultra branded bases can be easily removed by just unscrewing them. Just a few simple screws and it should come right off. May need to flip it over and just take a look at where it's screwed into the TV itself. Hope this helps!
Dec 31, 2007 | Protron PLTV-37 37 in. LCD Television
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
212 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
