Question about Tti Vacuums
Hoover spot scrubber sprayer not working well.
The sprayer just dribbles out water. The force of the sprayer has decreased significantly.
  • Tti Master
  • 18,391 Answers
You can replace both tubes if it helps or you can check for blockages and check the pump off the video below
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY
Posted on Oct 31, 2012
2 Suggested Answers
  • 240 Answers
SOURCE: hoover silver carpet scrubber wont
There are two common situations that can cause lack of pick-up. First is that the lid is not properly attached to the recovery tank. Make sure it is latched in back and snapped in place in front. The second common problem is that the duct on the front of the dirty water tank is missing. There is a plastic duct about the size of a slice of sandwich bread which slides into the front of the tank, and is removed when the hose is in use. A less common problem is that the large round rubber seal that the tank sits on has fallen off the suction tube on the motor cover.
Posted on Jan 29, 2011
Dirt devil spot scrubber not picking up
Hi there! There are a few reasons why your spot scrubber may not be picking up. Your dirty water tank may not be seated properly or the filter may be dirty Please try these steps.
1. Check the filter located on top of the dirty water tank. If dirty, rinse with water.
2. Check that the pour spout cap on dirty water tank is plugged.
3. Replace the dirty water tank. Make sure the dirty water tank is flush to the cleaner and seated properly.
4. Clean the nozzle of any hair or debris.
Hope this helps! For further assistance please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jul 03, 2014 | Dirt Devil SE2800 Spot Scrubber Handheld...
Hoover steam vac modal # F5915905
I can tell you this you need to replace the hoses and seals that run through the cleaner and are used to carry the water from one place to the next and replace the sprayers to
Mar 20, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My hoover steam cleaner will not put down the soap solution? Any suggestions!
The line may be clogged.
If you look in the tank see anything blocking?
No? Okay moving on. You may need to remove a cover or covers.
Find the lower end of the line / tube.
Carefully remove the line.
Now with safety glasses on take a can of air, and blow the the line & sprayer out. Replace all parts you removed.
In the tub, shower or outside. Add vinegar & distilled water to tank let set for 1 hour then see if it will work. Let the water go down the drain or outside. If this don't work you may have a bad sprayer switch.
Please let us know.
May 18, 2010 | Hoover F5842-9RM Steam Vacuum
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Decrease in suction
Check to make sure the round gasket seal, under the hood, is in place. It is a rubber seal that sits on the plastic pipe, under the corner of the recovery tank, when the tank is placed in to the foot. It seals the vacuum from the motor, to the tank.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Help!!
Look up instruction manual at
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=325fa4dd-0a38-48aa-b0b0-516143a0875a
Aug 23, 2008 | Dirt Devil SE2800 Spot Scrubber Handheld...
Vacuums Logo
421 people viewed this question
Top Tti Vacuums Experts
JoeVacs
Are you a Tti Vacuum Expert? Answer questions, earn points and help others
