Question about Subaru Vehicle Parts & Accessories
Why is there no idling when starting cold? - Subaru Vehicle Parts & Accessories
  • Subaru Master
  • 14,381 Answers
What kind of vehicle do you have Anne,year,make,model and engine size?
Posted on Oct 31, 2012
My 1994 samurai idles really high when I first crank it, but later slow down. is there anyting I can do to ?
From a cold start my sami idles really fast, but as I drive it and the engine warms up it will idle correctly. Is there a way to make it idle slower from a cold start?
what engine ? 1.3 L
carb or EFI? (94 was first year of efi, and many have been converted this old)
but the answer is the same , that is normal.
on car its a fast ilde cam on the carb.
in EFI its on the software and in the IAC thermal valve.
Mar 29, 2013 | 1994 Suzuki Samurai
The car starts easy when hot but when cold it takes long to start, what can be the course?
To troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Mar 14, 2013 | Cars & Trucks
Will not idle when cold
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Dec 14, 2012 | 1999 Jeep Wrangler
Won't start easily since it got cold (32degrees). It's fine once it starts
These will help.
Thanks.
Dec 14, 2012 | 2004 Dodge Ram 3500 Truck
Toyota rav4 diesel starting problems from cold it take a long time to start up when i leve it over night..
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Ford escort 55 van cold start problem 1.8 diesel 2001
COLD START PROBLEM
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Hard starting and rough idle
The idle valve is the most common problem for hard starting in cold weather. I would recommend having it removed and inspected for contamination. Sometimes they can be cleaned out. If it has heavy carbon buildup, you may have to replace it. (if the idle valve is removed, the shutter inside should easily move when you rotate it from side to side and you can also look at it with a flashlight for a visual inspection.
Feb 20, 2012 | 1997 BMW 328
Vehicle Parts & Accessories Logo
Top Subaru Vehicle Parts & Accessories Experts
Randy Ohler
Thomas Perkins
Thomas Perkins
Todd Arndt
Todd Arndt
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
