Dual 1246 turntable manual - Audio Players & Recorders
2 Suggested Answers
  • 11800 Answers
SOURCE: The turntable on my Dual
Since you don't hear the motor it means that it's not rotating. You need to find out why.
When you remove the platter you will see the mechanism and the electric components an d some of them can be tested using a simple voltmeter. You must verify them in this order:
- the power cable- that power is indeed reaching the power switch.
- the switch- located on then arm shaft - that it actually engages when the arm is moved
- the regulator board - that it's still connected and powered
- the motor itself - that its coil is continuous and the power reaches it.
Find the part that no longer transmits the AC power and replace it. If the motor itself is powered but it still doesn't turn then it's faulty - finding a replacement one will be difficult.
Posted on Nov 22, 2010
DUAL 1229 service manual
U sure you are not looking for help with a turntable? If so, state the issue. Dual 1229 Manual 3 Speed Idler Drive Turntable Vinyl Engine
Apr 02, 2017 | Sewing Machines
My Dual CS 430 turntable suddenly stopped playing - rest of equipment (radio, CD player, tape deck) okay. Can you help, please?
Amplifiers always take the sound of the turntable via a separate pre-amp from all other systems, such as radio and CD players. This pre-amp can go faulty killing the sound from the turntable only. If the turntable goes through the actions of playing the record, then this is the cause of your trouble.
Sep 20, 2016 | Audio Players & Recorders
How do you remove the turntable?
It depends on the turntable you have. For example Dual turntables with idler wheel drive have a spring round the platter's axle which has to be remove. Some Dual belt drive turntables have a bajonett lock, other a lever to be moved and some have only weight fixed platters. Most platters of direct drive turntalbles are just fixed by their weight and are removed with a strong pull. Greetings from northern gemany
Nov 08, 2015 | Audio Players & Recorders
I have no sound from my Dell 1210s
I think you mean Dual but not Dell. Any problems with any Dual turntables are well known here: http://www.dual-board.de/ You can ask your question in english even it is a german board.
Sep 06, 2015 | Audio Players & Recorders
What type of amp needed for Dual 505 turntable?
make sure a new amp has a phono input (a sensitive high impedance input)
Apr 16, 2012 | Audio Players & Recorders
My elderly father has a Dual stereo turntable CS415-2 with no manual and no power supply. It says at the back that it takes 12v DC. I've found various power supplies, one of which (200mA) made the...
A lot of these 12 volt turntables are designed to operate with an Audio System. If you find out that model number you should be able to get the specs on the turntable. Perhaps the System is around your father's house somewhere?
Dec 13, 2009 | Audio Players & Recorders
I need a DUAL 1245 Turntable owners manual
I found a DUAL 1245 Turntable owners manual at {_manualGenius}
Oct 06, 2009 | Audio Players & Recorders
Dual 1009. No audio from the stylus & humming.
Trace all the connections to the cartridge. One way to do this is touching all audio input lines with a metal or screwdriver (holding the metal part and not the handle) while connected to the receiver with the volume turned up a abit to hear the 60hz humming sound. A louder humming sound will indicate a good connection path. Check also for good shielding of the audio wires to the cartridge. Generally, it's a wire problem troubleshooting.
WARNING!!! don't do this unless you know what you are doing. Don't ever touch the AC voltage wires OR someone will hum your mishap :-)
Jan 13, 2009 | Technics SL-1200 Turntable
141 people viewed this question
 Grubhead
Grubhead
