Question about MagnaFlow 2003 Nissan Altima - 3.5L V6, with federal emissions system - Catalytic Converters
My o3 V6 Altima cuts out while driving and sometimes difficult to start afterwards-smells like gas fumes code is PO345 What is it?
My o3 V6 Altima cuts out while driving and sometimes difficult to start afterwards-smells like gas fumes code is PO345. I`ve tried carb & injector cleaners but problem is still there. What is it?
  • 512 Answers
Repost in Cars and Trucks. This is inverters.
Posted on Nov 06, 2012
I have a 1997 740il BMW. From time to time I smell
run the fault codes as it may be a faulty canister system or purge valve.
Aug 30, 2014 | Cars & Trucks
Code comes of for leak evac the shop ran smoke and could not find a leak I got a new gas cap, I don't smell gas help?
Make sure the computer has been reset since changing the cap. Autozone, etc. will scan for free.
The smoke test should have caught the problem provided the shop looked at the gas tank too. There can be a problem in the electric solenoid valving for the canister which can be concealing a leak beyond the solenoid valving. If the solenoid is closing off the flow, then it can also close off the leak.
As for smelling gas, its the fumes which flow in these hoses, not raw gas. If the Vacuum system draws the fumes in, or if the leak is rearward, there is less of a chance of smelling the fumes. Rushing air from driving will dissipate many fumes.
Dec 23, 2013 | 2000 Ford Focus
I have a 1999 oldsmobile alero ... i'm smelling gas fumes as the car sits w a/c or heat on ..gas needle dosent work properly.. and humming noise...seems to smell strongest when low on gas..went t
For the first problem, if you can get me the codes I may be able to help you figure out the problem with the gas smell. The fuel gauge problem could be the gauge on the dash or the sending unit in the tank.
You should have the body computer scanned for trouble codes to find out whats going on with the ABS and traction control.
I have no clue on the humming noise.
Aug 09, 2012 | 1999 Oldsmobile Alero
The gas pedal was pressed too much before starting and now it doesnt start and it smells like gas a lot
It is flooded. Sometimes difficult to start afterward
if this is the case you have to floorboard the gas pedal - which floods the carb more so and keep it there for two minutes. Then try starting it. If and when it starts - ease off the gas or blow the engine.
Feb 05, 2011 | 1997 Pontiac Sunfire
Turns over well but is slow to fire off sometime. Can smell gas fumes inside the car as well as the outside. No black smoke from ehaust and no fuel leaks.
if you smell gas YOU DO have a fuel leak.... make sure your gas cap is good and or tight, also might want to look at your fuel pressure regulator.. the fuel system is pretty simple... let me know!
Jan 22, 2011 | 2003 Nissan Altima
I have a 2001 civic ex manual trans with 67,000
Sounds like the clutch is worn or the throw out bearing. You will need to have both checked. As far as the gas fumes go, check your air filter to make sure it doesn't need to be changed, if your fuel injected check to make sure you don't have leaks around your injectors. Finally check the gas fume collector for damage or bad vaum lines.
Jan 25, 2010 | 2001 Honda Civic
When you fill the gas tank you can smell fumes but it is not leaking on the ground.
There are, of course, many possibilities, but if you are smelling fumes it is likely that they are coming from the engine compartment. If you smell the fumes when you first start the car, it may be that one or more of your fuel injectors have begun to leak. They are the four cylindrical devices connected to the fuel rail down low in front of the cover that is marked PGM-FI. You would be able to see dampness on one or another if it is leaking. Another possibility is a leak in the fuel line itself regarding its several connections. Without a manual and pics, it is difficult to indicate the positions of many parts, but if you trace your fuel line backward from your fuel rail to the fuel filter and so on, you might be able to find a leak. A VERY small amount of fuel will allow you to smell it, so I wouldn't expect to see gas flowing out somewhere. Sometimes, simple overflow from filling the tank will give you a short-term odor.
Sorry I can't be more help. A Haynes manual would be a good investment.
Oct 13, 2009 | 1992 Honda Accord
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Jun 06, 2008 | Ecoquest Living Air Classic Air Purifier
MagnaFlow 2003 Nissan Altima - 3.5L V6, with federal emissions system - Catalytic Converters Logo
Top MagnaFlow Electronics - Others Experts
Fred Sops
gbob59
Lawrence Oravetz
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
