Question about Measuring Tools & Sensors
ISV Temp Probe Error,Air Purg Not Working - Measuring Tools & Sensors
2 Suggested Answers
  • 15557 Answers
SOURCE: Soleus Air PE8-12R-32 Air Conditioner, shouldnt the plastic temp probe be placed somewhere else on the unit for a different temp reading rather than placed in the same (tube)/as the copper temp probe
2 Functions, the coper line is for an expansion tube or a physical thermostat and the plastic one is for the display
Posted on Jul 23, 2016
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Masterbuilt ea2 error code
Same problem here. Any answers yet?
Jan 02, 2014 | Masterbuilt 20070106 Electric Smoker
DISPLAY READS HIGH PRESSURE UNIT DISABLED
This is a common problem of Robinair 34700Z / 347002K & 347112K series machine. So don't worry just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full, carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify if there is high pressure in the ISV tank. Purge excess air from the tank manually. (Open air purge hose from the ISV tank, then carefully press tank valve as needed to blow out excess pressure from the ISV tank)
After doing all above stapes and your problem still exist then replace air purge solenoid (Air purge solenoid located near the ISV tank and fixed with automatic air purge device). Hope this will solve your problem, if so please vote for it for farther help! Good luck
May 17, 2011 | Robinair Cool Tech 34700Z Recovery,...
High pressure unit disabled on unit
If your machine is one of the bellow Model:- Robinair 34700Z / 347002K & 347112K series. just do the following, with POWER SWITCH OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full, carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify if there is high pressure in the ISV tank. Purge excess air from the tank manually. (Open air purge hose from the ISV tank, then carefully press tank valve as needed to blow out excess pressure from the ISV tank)
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have a Canon printer modal No MP830 AND I,m getting an error message 6A00.
the error code 6A00 means :
  1. an error occurred in the motor during the purg operation
  2. check the purg unit if it's broken replace
the picture of the motor: mabroukmedal_28.jpg
Dec 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How to remove refrigerant manually form isv
Open air purge hose from the ISV tank,then press tank valve as needed to purge air from the tank
Sep 07, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34788 "air purge not working"
Please check ISV tank air purge (pressure) transducer & 12V DC discrete Solenoid ( both lacated on top of ISV ), it sounds like defective!
NOTE: Never use Automatic Mode till you are not very familiar with this machine
Jul 06, 2010 | Robinair Cool Tech 34700Z Recovery,...
Ambient air temp is readying high on my 2007 Ford F150, possible causes?
Usually it is the temp probe on the radiator support behind the grille.
When you pop the hood there are 2 probes there, 1 in the ambient air temp probe, the other is the front impact severity sensor. temp probe has the little probe sticking out of it. I have seen mixed results on replacing this, some it corrects the issues, others are still not happy after the replacement. I make the assumption ( bad thing some times ) that the ones that are unhappy are using an incorrect comparison temp sensor ( bank sign, etc ).
Feb 25, 2010 | 2006 Ford F-150
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Measuring Tools & Sensors Logo
257 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
