Question about Panasonic Televison & Video
When connecting the cable it spark. Why?
There was lightning, so I disconnect the cable line from the wall. When reconnecting the cable line it sparks and get hot.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
The cable line may be hot now because 110 volts has got to it----someone needs to check the coax from a known earth ground to see if hot----it can be any appliance connected to something with the coax attached---have it checked and be careful as this could be dangerous.
Posted on Oct 31, 2012
Spark plugs change
generally the procedure is the following:
- stop the engine
- take off any obstructing panels
- disconnect spark plug cables
- using a spark plug wrench, remove the old plugs
- install the new ones (see your manual for what sort of spark plugs you need)
- reconnect the cables
- start your engine
here's a video example of a 2003 honda shadow spark plug change:
http://www.youtube.com/watch?v=t7b1GropyXE
Jan 24, 2014 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Check engine light came on after changing spark plugs
Check to make sure all spark plug wires are in correct firing order,ceck all spark plug wire conjnections & make sure connections for tightness.Disconnect - battery for 10 seconds & reconnect battery cable code should clear if problem is still present
May 30, 2011 | 2002 Nissan Sentra
When I print, on the paper there is several blue verticle lines at the top of the paper and halfway down and some of the lines are broken. Thankyou Tom
Reset the Printer If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product. Make sure the product is on, and then disconnect the power cord from the product.
  1. Disconnect the USB cable from the product, and then disconnect it from the computer.
  2. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  3. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  4. Reconnect the power cord to the product.
  5. Press the Power button (c02062868.gif ) to turn on the product. If you have duplexer try to open it and clean the rollers of the printer and the duplexer. This usually happens if the rollers are dirty.
Mar 26, 2011 | Office Equipment & Supplies
Battery drain, I just bought a new battery but for some reason it get drain if not plug into a tender. What could it be? Stater or regulator?
It could be most anything including the new battery. Odds are that it's not the battery but never rule that out. I've bought a lot of bad batteries before.
But, let's do it this way. Disconnect all the wires off both terminals of the battery and reconnect only the large cable that goes to your starter on the positive side. Now, find the wire that runs from your voltage regulator back towards your battery. On some bikes this wire connects directly to the battery and on others it connects to the starter terminal where the battery cable connects. Disconnect this wire and reconnect any wires that were on the connector with it. What you're doing is isolating the voltage regulator. Now, touch the negative battery post with the negative cable. Watch for a spark. If you see a spark, something else is draining your battery. Now there are certain things that run all the time on your bike such as the ECM needs power all the time, the clock, and maybe a few other things. But if there's a rather large spark, it's probably something else. Also, if it's a large spark with the regulator disconnected, it's probably not the regulator.
Now, remove all the fuses from the fuse box. Remember what fuse goes where. Do the spark test again and notice the size of the spark. Start adding one fuse at the time and doing the test. When you put a fuse in that dramatically increases the size of the spark, your current load is more than likely on that circuit. You'll need a schematic to find out what is on that circuit.
If you don't like the "spark test" and want a more professional way of doing it, you'll need a DVOM (digital volt ohm meter) that will measure at least ten amps. Wire the meter in series with the negative post of the battery and negative battery cable. If the meter reads a negative number, reverse the lead connections.
Good luck
Steve
Sep 12, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
How to change spark plugs on a 4cyl 2005 kia sportage
Inspection
Inspect the spark plug tip for wear and damage. If the tip is covered with carbon, replace the plug. Do not drop or shock the spark plug. If the ceramic body is broken replace the plug.
Fig. Spark plug inspection points
Removal & Installation
WARNING Do not attempt to remove spark plugs when the engine is hot.
  1. Disconnect the negative battery cable.
  2. Remove the air intake hose assembly.
  3. Remove the accelerator cable bracket.
  4. Remove the six bolts and coil cover from cylinder head cover.
  5. Remove the four bolts and the two coils from the cover.
  6. Disconnect the high tension leads from the spark plugs by twisting the boot and removing.
  7. Use compressed air to remove any dirt from around the spark plug hole.
  8. Make sure the spark plug socket fits squarely on the spark plug, and then remove.
To install:
  1. Be sure the spark plug gap is set to 0.039-0.043 in. (0.98-1.09mm).
  2. Apply anti-seize compound to the spark plug threads.
  3. Carefully install the spark plug into the cylinder head and torque to 11-17 ft. lbs. (23 Nm).
  4. Reconnect high tension leads.
  5. Install the two ignition coils and torque four mounting bolts to 14-19 ft. lbs. (26 Nm).
  6. Install the coil cover and secure with six bolts
  7. Install the accelerator cable bracket.
  8. Reconnect the air intake hose assembly.
  9. Reconnect the negative battery cable.
Have a nice day. Good luck (remember rated this help)
Mar 05, 2010 | 2001 Kia Sportage
Where are the spark plugs
Instructions Things You'll Need:
  • Spark plug socket
  • Socket wrench with extender
  • Anti-seize compound
  • New spark plug
  • Tension tester tool
  1. Step 1 Raise the hood and locate the battery. Disconnect the negative battery cable. Allow the engine to cool before attempting this process. Depending on the climate, it may take 30 minutes or more to cool the engine.
  2. Step 2 Find the spark plug cables on the Kia Spectra engine of either a four- or six-cylinder variety. The number of cylinders indicates the number of spark plug cables on the engine.
  3. Step 3 Turn the cables by the boot, or cover, that connects to the engine or directly to the spark plug. Disconnect one cable and complete the replacement process before removing the other cables to ensure the cables don't cross. Pull back on the cable to reveal the spark plug.
  4. Step 4 Remove the spark plug from the cylinder well with the socket. The extender may not be needed for 4-cylinder engines. Turn the socket in a counter-clockwise motion to unscrew the plug and remove it from the cylinder block.
  5. Step 5 Use the applicator supplied with the anti-seize to spread the compound over the threads of the new spark plug. This compound allows for easy removal when you need to check or replace the spark plugs.
  6. Step 6 Screw the spark plug into the cylinder well by hand. The spark plug needs to be tight in the well but may have to be loosened after the tension test finishes.
  7. Step 7 Test the torque of the spark plug with the tension tester tool. Normally the spark plugs on a Kia Spectra need 18 to 22 ft-lbs torque. Check the Spectra model's owner's manual or the manufacturer's package because some premium or performance spark plugs use different torques.
  8. Step 8 Reconnect the spark plug wire and turn it to lock it in place. Continue replacing the rest of the spark plugs. Reconnect the battery cable after you replace all the spark plugs.
Oct 27, 2009 | 2002 Kia Spectra
How do i change the spark plugs on a 2003 kia rio
INSPECTION
1. Disconnect high-tension code from spark plug.
2. Remove the spark plug.
3. Connect the spark plug to a high tension code.
4. Hold the spark plug with insulated pliers 5~10mm from a ground.
5. Crank the engine and verify that there is a strong blue spark.
If there is no spark, inspect the following points.
Step Inspection Action
1 Check for good connection of ignition coil Yes Go to next stop.
No Repair or replace
2 Check if resistance of high-tension leads are OK Yes Go to next step.
No Replace
3 Check if the ignition coil is electrically charged
1) Ignition switch "ON"
2) Check if the engine coil (+) is electrically charged
Yes Go to next step
No Check the wire harness between ignition switch ignition coil and ECM
4 Check if resistance of ignition coil is OK
Resistance
Primary : 0.36~0.44Ω (at 68°F (20°C))
Secondary : 10.9~13.3kΩ (at 68°F (20°C)) Yes Go to next step
No Replace
5 Check if ECM is OK Yes
No Replace
REMOVAL
Do not attempt any maintenance on spark plug if engine is hot.
1. Disconnect negative battery terminal.
2. Carefully remove high-tension leads.
3. Use compressed air to blow any dirt or debris from around spark plug hole.
4. Check that spark plug fits squarely in spark plug socket and remove spark plug.
Raise a vehicle and install SST(OK552 131 001) in order to replace cylinder 2, 4, 6 spark plug.
INSTALLATION
1. Install spark plug into cylinder head.
Tightening torque : 18~22lb-ft (25~30N·m, 2.5~3.0kg-m)
2. Reconnect high-tension leads.
3. Reconnect negative battery cable.
Jul 17, 2009 | 2002 Kia Rio
Change spark plug wires on 04 kia sedona
REMOVAL OF THE PLUGS:
INSTALLATION:
Hope this helps and simple to understand. Good luck
Apr 20, 2009 | 2004 Kia Sedona
1998 nissan frontier misfireing
check spark plugs.
with the engine running (idle)
disconnect one spark plug cable,
see if your engine goes at lower speed or notice engine speed variation.
if it does, the spark plug is OK. it no change, the spark plug is bad.
reconnect the first one then disconnect the next plug.
do this untill at the last spark plug connection.
Nov 06, 2008 | 1999 Nissan Frontier
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
