Question about Euro-Pro Shark 60 - 384
Presser foot lifter will not lift from down postion
Presser foot is stuck in down position. I have tried applying a lot of force to get it up but I do not want to break the lever. Need to know how to make it lift again.
4 Suggested Answers
Sewtech1
  • 69 Answers
SOURCE: we jave pfaff 1471 mod - pls explain how you get
it seems like it is dry and needs some sewing machine oil on the shaft.
Posted on Oct 04, 2009
  • 1788 Answers
SOURCE: I just bought this machine and I am trying to wind
Call Euro Pro at 1-800-361-4639 and see if it is a problem with your model and if there is a fix for it.
Posted on Jan 31, 2011
SOURCE: My presser foot won't go up and down. Any suggestions?
it's very possible that a part in your machine has come loose or broken
it needs to be serviced
Posted on Feb 01, 2012
Presser foot lifter
foot pressure needs adjusting
Feb 10, 2014 | Bernina Sewing Machines
Can't get my presser foot to fall down when I let go of the lifter on my Pfaff 6085 sewing machine
Sounds as if the spring for the presser bar is broken OR the presser bar is dirty and needs cleaned and oiled.
Feb 25, 2013 | PfaFF Sewing Machines
I have an activa 130 and the foot won't go all the way down
Is your machine fitted with a knee-lifter ? If so, its possible the knee-lift mechanism has got stuck, which will prevent the foot from coming all the way down. It's also possible that the foot lifter bar has slipped which will require re-setting. When the foot is lifted and the feed-dogs are dropped, there should be a clearance of about 7.5mm between the underside of the foot and the stitch plate.
Mar 02, 2012 | Bernina Activa 130
Hi, the presser foot is stuck in the down position. The presser foot lever has no effect at all. As I have a project underway, I'm having to lift the foot by hand while I get the fabric under the foot but...
You need to get access to the pressure foot bar area. Open the side cover if you can and look to see where the pressure foot lifter lever meets the pressure foot bar lifting block. Maybe the block has sliped upward. You'll need to loosen the screw, slide the block down a bit, tighten the screw, and check to see if this works. (Not knowing what machine you have)
Apr 25, 2011 | Sewing Machines
Husqvarna rose tried to run it and the pressure foot light comes flashing on and will not run. yes the presser foot is in the down position
There is a safety switch underneath the presser foot lever, its tucked away in the body cavity and its tough to see. The switch is operated by a metal spring that turns the switch off and on according to the presser foot lifter position. the spring, which kinda looks like a fork, gets compressed each time you lift the presser foot. It wears and works intermitantly. A dealer is the only solution, the back needs to come of, and its a dang tough job to replace without damaging the replacement spring.
The other thing it could be is a jammed check spring inside the tension assembly, again its a tough job as the auto tension assembly must be removed, along with the winder and loosening of the main board.
derek
Jan 15, 2011 | Husqvarna Rose
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Can't lift handle for my foot presser
Take the machine apart to the point where you can see the pivot point for the presser bar lifter and spray WD40. Let sit for a few hours and try again. Repeat until the presser bar lifter releases.
Sewing Machine Parts
May 18, 2009 | Kenmore 15208 Mechanical Sewing Machine
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
Euro-Pro Shark 60 - 384 Logo
32 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
