Question about Kenmore 74992 Gas Dryer
MY KENMORE MODEL 110.76722694
My Dryer will comes on for 5-10 minutes then shuts off. if we try to restart it will make a buzz sound but will not turn on. when we try to force the dryer on it does not make buzz sound it will not do anything.if we leave dryer alone for 30min to one hour it will start again. sound funny while running. the dryer heats fine once started. any suggestions?
  • Anonymous Mar 25, 2014
    dryer makes buzz sound but won't come on
  • 87 Answers
You have a bad motor. You can remove and verify probably bad bearings and burnt start winding.
Posted on Jun 08, 2007
Dryer shuts off prematurely. When I try to restart, it just buzzes. After an hour or 2 it restarts, but shuts down again after 20-25 minutes.
It is overheating for some reason , make sure the filters are clean and the dryer is not close to any wall. make sure the drum is free to turn and not binding.
Dec 03, 2015 | Dryers
Need Kenmore 80 series, gas dryer wiring diagram. dryer overheats after 15 to 20 minutes, with a full load of clothes, then shuts off...........wait 20 minutes, then I can restart; ...
you need to send the model number kenmore doesn't make anything,the only way to tell who made it is by the model number but anyway if it stalls on you and you go to restart it does it make like a buzz sound if so you have a bad motor,when the motor cools off it starts again,it's not a t-stat or anything because when they fail they won't work again non resettable,most likely will be the motor
Dec 29, 2017 | Dryers
My dryer only runs for about 5 minutes then shuts off, as if overheated. You have to wait about 10 minutes before it will start when you push the button, only for it to last only another 5 minutes.
Sounds like you might be causing the thermal overload of the motor to open shutting down the dryer. Try cleaning out all the vents--external to the outside and internal to the dryer. Cleaning out the internal ones will require you to open the dryer up. Be sure the dryer is unplugged before any work is done to its internal workings or the control panel is accesseed. Often times, lint inside the vent or just inside the dryers internal areas can collect near the motor and overheat it. Cleaning this out may aleviate your problem. If this does not work, it may be time to look at a new motor--or dryer replacement. Usually when a motor starts to have internal electrical winding problems there will be a horrible sounding buzz upon start up. Remember, a thermally overloaded motor only has so many restarts before it is done.
Feb 05, 2011 | Maytag Dryers
My dryer starts the first time with no problem, but after about an hour it starts to make a kind of buzzing sound. If I don't shut it off at this point it shuts itself off after another minute or two....
You are absolutely correct that the motor is the problem and needs to be replaced. The motor is overheating and its thermal overload protector trips off causing the dryer to shut down. Thermal overload protector resets and allows the motor to run again only when it has cooled down. It is the reason why the dryer is not turning on immediately after it shuts off. Replacing the motor will definitely solve the problem.
Aug 11, 2010 | Maytag Dryers
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Kenmore Clean Touch dryer making buzzing sound and
Ya, happened to me. Sounds like you may have a clogged vent. (in the tube, or the dryer itself. Try cleaning that out really good. Then, double check that the venting is secured properly. If not, may overheat and shut down. I think that's what's going on. After you clean tubing (And the inside tube on dryer), the buzzing will continue for a while (days) until itr resets. If it runs after this, but still buzzes, that's your problem. Hope this helps you!
May 09, 2017 | Whirlpool LGQ9858P Gas Dryer
Hunting boots no no!
If you have one of those fubuloso wrinkle guard whirlpools, they will buzz and start back up on their own in the cool down portion of the cycle the idea being the 2nd timer will keep the clothes from wrinkling by buzzing and then coming to life for a few minutes. Then it waits 10 minutes and if you aint got the clothes out or opened the door then it will repeat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
Kenmore 74992 Gas Dryer Logo
180 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
