Question about Kenmore Elite HE4 Electric Dryer
Clothes not dry and get F70 code
Kenmore e lite smart heat quiet pak 4 HE3 dryer
  • 15,935 Answers
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
F70 and F71 are two logic board error codes that point at a communication error between the main log
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
327 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
