Question about Frigidaire GLTF2940ES Front Load Washer
Frigidare fws833a51 leaks by the aggitator shaft
  • Official Brand Answer
  • 4,342 Answers
Hello - In this particular case I suggest taking the agitator apart for properly cleaning. Once you have done so and tested again, if issue continues contact a professional to move forward accurately. Washer may be experiencing a damage or crack part that has to be further diagnosed.
Posted on Nov 02, 2012
  • doller_holle
    doller_holle Nov 03, 2012
    Thank you Chris,after following your advice,it turns out that a bearing was leaking,and so,the washer is now on it's way to be "recycled",i appreciate your timely response!!
My top loading frigidaire washing machine barrel spins during wash cycle and the aggitator is going as well how do i fix it
Hello fire_rod - From what you have described it sounds like either the transmission is failing or the trunnion, which secures the tub to the transmission shaft has broken. Contact a professional to move forward accurately.
Dec 16, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway ..mm
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
I want to replace the aggitator but cant pull it
Some models have a fabric softener dispenser located at the top of the agitator that must be pulled off so you can get access to the fastener that holds the aggitator onto the transmission/motor shaft. Some are just pressed onto the motor shaft and after years of use, get gunked up (yep, that's the technical term for it!). You can pour some hot water down the agitator tube to help flush out the gunk and that should make it easier to remove the agitator.
Also, check along the bottom of the agitator to see if there is a small hole that might be concealing a locking set screw that is holding the agitator onto the shaft. It varies from model to model, so look all over and around the agitator before exerting any force in an attempt to pry it off the shaft.
Try to get your hands under the bottom lip of the agitator at the 3 and 9 o'clock positions and try to rock it back and forth while pulling up and it should work itself free.
Just be sure you have removed any screw or hex headed fastener that could be holding the agitator onto the shaft 1st!
Jul 28, 2009 | Kenmore Washing Machines
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
254 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
