Question about Cisco Computers & Internet
Changining my wifi passphrase
I just want to change my password for my wifi
  • 564 Answers
Connect your pc to the router with ethernet cable.
open web browser and in the address bar type 192.168.1.1 (if this doesn't work try 192.168.1.2)
you should get your router's home page.
when asked for user and password type admin for both.
if that doesn't work try admin and password
go through settings to where the password is and change it.
save the changes and you're done.
Posted on Oct 31, 2012
I have a PK5001z. I can not get the modem to accept the password to join IPhone to modem. Is the password the key/passphrase? What do I need to do to make modem to accept the password?
Check your PK5001z wifi security mode. If it is WEP, you will need to change it as WEP is old and not compatible with many smartphones. Change it to WPA and you should be able to link to the iPhone.
Sep 19, 2015 | Computers & Internet
Find network key on sb6141
The term "Network Key or Passphrase" indicates your printer is asking for a WiFi password, but the SB6141 is not a WiFi capable device at all, it's just a Cable-to-Ethernet device. So then, you need to look at your WiFi router, which should be connected with an Ethernet cable to your SB6141. If this doesn't match your setup, you'll either need to get a WiFi router hooked up (that process will contain the answer to your question) or simply use an Ethernet cable for your printer.
Nov 09, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Want to add iPad to network but dont remember my password
What you want is to add an iPad to your network. If you mean logging in on your Wifi at home, that is easy, but you probably mean you have lost the password of the router.
Reset the router to factory default: pull the plug and leave it unplugged for at least 10 minutes.
Check on the backside if it has a sticker with the default passphrase. After starting it up try this passphrase on the iPad.
If it has no sticker: Try Google: type in your brand and model of router with added "default wpa password". This might give a default password for your router on some site.
Do learn to adjust the password on your router: mostly you can type the IP address of the router in your browsers address bar
Try 192.168.0.1 or 192.168.1.0 (might be mentioned on the sticker also) then you get a weblogin page for the router.
Mostly you will need as user 'admin' and a password on the sticker.
Search for WPA2 passphrase in the setup and set that notch and adjust to your own password.
Use this password on the iPad:
goto settings - wifi and choose your network, give in your own password.
Good luck!!
Aug 26, 2014 | Computers & Internet
Need to change wifi passphrase to all numbers or all letters smart tv doesn't recognize letters and numbers
you can auth your tv to use wi-fi without password via mac from wify setup when detected.
disable passphrase from router and connect tv, auth tv and pus back passphrase and it should work, if not, change security type of router to another, WPA/WPA2 where it would let you enter any password you like.
Feb 26, 2014 | Computers & Internet
Passphrase key
Get passphrase (password) from the wireless router you are trying to connect to. No one online can give you that without access to your main computer.
Oct 10, 2013 | NetGear RangeMax Dual-Band Wireless-N USB...
Don't know wifi password
To find your WiFi password, locate your Wireless Access Point (Might be built into the Modem) and look on the underside if it. There will be a lable saying "WiFi name", "Passphrase" etc. That Passphrase is the WiFi password.
Dec 27, 2012 | Facebook Social Network
I hav recently purchased a new printer HP PHOTOSMART PLUS B210 Series. I am having trouble integrting the printer tomy wireless network. The printer is asking for a WPA PASSPHRASE, but i cannot locate my...
Do you know the password to your WiFi-network? (that is the WPA passphrase)
i you have forgotten the password, you can change it by logging on to your router and settings a new wifi password.
you can find out your routers adress if you go to start - run.. and type in cmd and hit enter there you get a black screen, type ipconfig /all (followed by enter) and look for default gateway (thats the adress to your router)
often http://192.168.0.1
May 05, 2011 | Computers & Internet
How to set a security cod for wifi
This is a Quick and easy fix!
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
Trying to connect my wireless epson printer to Netgear router WPN824. When setting up the printer it finds the SSID but after I enter the passphrase and say OK it tells me that the connection is...
Launch a web browser from a computer or wireless device that is connected to your router's network. Type http://routerlogin.net into your web browser's address bar. The user name is adminand the default password is password.
Check or set your WiFi password/passphrase. Here then on any wireless device you want to connect.
if you have 2.4 AND 5.8 ghz you have to set the SSID & passphrase on both.
May 11, 2017 | NetGear Computers & Internet
Forgot password to WiFi How do I find out what it
To find the password/passphrase on the Linksys router, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router. On older models the username is left blank and the password is “admin”. On newer models, both the username and password is “admin”.
Once you get in to the router management tool, look for the security portion. There you will find the password or passphrase you are using for your WEP or WPA security encryption.
Dec 01, 2009 | Linksys WRT160N Wireless Router
Computers & Internet Logo
204 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
