Question about Toshiba 57HC85 57" Television
No color only displays black and white - Toshiba 57HC85 57" Television
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Disconnect set and anything connected to it from power for a while to see if when power is connected back all the units will reboot--may help and is easy to try.
Posted on Oct 31, 2012
Display loses color after start up turning black & white
I wouldn't think that was the problem I would check the settings.
Mar 17, 2014 | HP G60-120US Laptop
My dvd's play in black & white. cant get any color in pitures.
There are three types of display settings. 1 PAL, 2, NTSC and 3, Auto.
The pal and auto makes a display show color while the NTSC allow a display show in black and white but sometimes NTSC also shows color. It is possible that the display format on the movie is NTSC.
To fix this problem, play the movie that shows black and white. When the movie shows in black and white, press PAL/NTSC or P/N on the remote control and it should display in color.
Or Go to the player menu, check video or display setting, change it to Auto.
Problem should be fixed because that's where it lies....
But if it doesn't solve the problem, please let me know so that I may direct you further on what next to do.
I hope you understand the above.
Good luck.
Mar 04, 2011 | Philips Audio Players & Recorders
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
Printer A10922 will only print in black. Color cartridge renewed 1 year ago and has been working well.
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
My playstation 2 plays in black and white instead of color. How do I fix this?
I guess your console is NTSC and your TV or the display you connecting your playstation to is pal or vice versa
you would need NTSC to pal converter if there is no color on the display
Dec 18, 2008 | Bethesda Softworks Black & White
Toshiba 57HC85 57" Television Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
