Question about Sony PlayStation 2 (PS2) Console
To Arpi > PS2 U.S.A. version (110 volts) SCPH-39001 charged to 220 volts - is it burnt already?
Is it still repairable? i hope it is just the "fuse" it was tried on an electric socket with 220volts and it smell burned..please help me!
    Novelist:
  • 201 Answers
This would have damaged the power supply, most likely not harming any other parts. Fuses do not smell when they blow so something else was damaged. I would suggest looking for a similar revision that has a blown laser or other trouble and use the power supply from that.
Posted on Jul 12, 2007
Sony playstation model no.scph- 39001 wont run browser
There are no browser on playstation 2, for an online play you need a network adaptor or slimline ps2. Still when i checked for example killzone 1 multiplayer like 5 years ago one lonely person was playing so it's not worth the cost and trouble.
Jan 27, 2014 | Sony PlayStation 2 (PS2) Console
I plugged my desk top to 220 volts line instead of 110 volts
Most likely the damage is too great to be repaired and if it can be repaired the cost of repairing may not be worth it.
If it was me I would put my money towards a new computer.
Jan 04, 2013 | Dryers
I have one AC 90 110 volts, and have used it in 220 volts. I think the internal fuse is broken. The solution is only change the broken fuse for a new one?
That will be step 1 to what will probolly become quiet a bit of problems. I'm not huge on this unit but generally speaking if you opened the chassis your going to see a few burnt components (rectifier,diodes,transistors). But lucky 220 hits so hard it's usually just a replace the stuff you see burnt (get schematic if possible) it's a pretty straight forward repair.
Sep 08, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
PS2 bad power supply
Greetings Xwrongwayx,
My suggestion is if it will plug into the newer unit, then it is fine to utilize the older power supply. I have two different PS2 units, and we use the cords for either to plug the units in.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 16, 2008 | Sony PlayStation 2 (PS2) Console
USB based joy stick
Well, assuming that your machine is an S.C.P.H.-39001/ 30000-50000 model, there should be two U.S.B. Ports on the front of your machine surrounded by a blue square, just below the memory cards and Controllers.
Jan 07, 2008 | Sony PlayStation 2 (PS2) Console
PS2 110 volts charged to 220 volts
Hello. I think is it is repairable. Please give me the model SCPH..... and I will try to help you. Best regards, Arpi
Apr 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
234 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
