Question about Motorsports
Toyota 2C diesel
Tuning diesel motor, Currently too rich mixture
SOURCE: Toyota 2C diesel pump
Did you come right with the drawing?
Posted on Aug 14, 2008
pippall
  • 1486 Answers
SOURCE: idle is rough and rich after warming up 1986 toyota 4wdwagon 3 ac
sounds like you are not geting the right amount of air to fuel system.Have you checked the air filter is clean.Change the air flow senser if it is clean.Good luck!!
Posted on Jul 07, 2009
  • 13 Answers
SOURCE: cambelt timing on 2c diesel toyota
its probably your injectors, does it have over 200,000 kms or been poorly serviced at some time? have you replaced your airfilter? diesel cars also loose compression when their oil is old, and will idle differently and smoke more..
Posted on Mar 09, 2010
SOURCE: i have 1991 toyota levin 4age motor at idle revs
my engine check light on 4age engine dim before start, will not go off after started and slump throttle black smoke from exhaust
Posted on Mar 13, 2010
ZJLimited
  • 17970 Answers
SOURCE: Scanner code dtc:26 mixture control continuously
DTC Code 26 Air/fuel ratio RICH
Did you GAP the plugs right? If not, that code will appear on it and a bad O2 sensor will cause it to give off that code also,have someone with a good scanner read and monitor the O2 sensors on it while its running and that will tell you if they are with in range; if not replace the bad ones on it.
Hope helped (remember comment and rated this).
Posted on Jul 27, 2010
Toyota 2c. I need cylinder head and flywheel Torque settings
Toyota 2c ...
USE NEW BOLTS...
Torque sequence:
You're driving a diesel single cylinder head engine. Engine head torque has to be done in specific order and stages if not can warp head or break bolts. Suggest you get torque sequence and torque specs from your Toyota dealer, they can give you correct answer. Don't trust answers on here, if you choose wrong specs. could end up messing up head.
Flywheel - Use a Sealer on bolt, Manual Transmission 88nm/65 ft lb... Auto Transmission 74nm/55 ft lb
Aug 06, 2014 | Cars & Trucks
Toyota previe 2.2 diesel that has started to smoke a lot when cold, the smoke is a greyish colour.
its too rich.
get the FSM and read how to test parts that control fuel mixture.
mech. injection
or EFI injection
Feb 04, 2014 | Toyota Previa Cars & Trucks
Free manuals
If you know how to use Bittorrent clients such as uTorrent, here is a magnet link which may help: magnet:?xt=urn:btih:978F63FB38A5A9DB70DA99FA47F4172442F20360&dn=toyota+1c+2c+2c+t+diesel+engine+repair+manual+rar&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80%2Fannounce&tr=udp%3A%2F%2Fopen.demonii.com%3A1337
Jan 16, 2014 | 1988 Toyota Lite-Ace
2C diesel , fuel adjustment
Diesel fuel will not actually freeze at any possible outdoor temperature, but it does lose performance when it gets frigid outside
if you need an auto tool you can click here: great tools
Oct 31, 2012 | Cars & Trucks
Toyota 2c turbo diesel timing
why their is a back pressure in water system what is the cause,when you accelerate ,the accelerator.he water comes out on the radiator filling valve?
Nov 28, 2009 | Toyota Camry Cars & Trucks
Clean intercooler.Full of engine oil
Nov 28, 2009 | 2008 Toyota Camry
What is fuel air mixture screw settings on husqvarna 371k
I will admit that I am not particularly familiar with this manufacturers specific models, but I will state that for most small 2 stoke motors I seem to find that 1.5 turns out seems to be a great place to start for both the high and low speed mixture screws. From there it is all fine tuning to get the most out of the engine while still keeping it rich enough to prevent damage.
May 06, 2009 | Husqvarna Garden
Jun 19, 2008 | 1992 Toyota Corolla
Motorsports Logo
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Trp Nap
Trp Nap
Level 1 Expert
Are you a Motorsport Expert? Answer questions, earn points and help others
