Question about Dual XDM6825 CD/MP3/WMA Player
No back light on the XDM6820
Did you find a solution to the problem. I am still looking.
Set clock on xdm6820
With the unit on, press and hold DISP until the clock beginsto flash, then release. Press TUNE << to adjust the hours and TUNE >>
to adjust the minutes. Press DISP momentarily to save the selected time.
Dec 24, 2015 | Dual XDM-6820 CD Player
I am looking for a face plate XDM6820 for a car radio.
  1. so who knows what kinda malware this site is spewing.
  2. But if ya still looking for a xdm6820 faceplate I recently aquired one in auction
  3. You still got the deck?
  4. july 06 2014 today is 3 18 2015
  5. Dallas Tx area
Jul 06, 2014 | Dual Audio Players & Recorders
My Samsung ln40a530p screen looks good and normal for a few minutes right when I turn it on. Then it gets real dark and not as clear and I can see images burned in the corner from a channel that was on...
That symptoms have problem in back lights supply.The back lights have drive board that energies the back lights, the drive board have 24v dc from the power supply.So if the 24V dc output of the power supply have faulty because of leak capacitor,the back light drive board is did not oscilate to energies the back light.So the problem is either in power supply the 24v dc output,the drive board or the connector of the back lights in the drive board is loosen.
Aug 31, 2011 | Samsung LN40A530 40 in. LCD TV
My xdm6820 has no display showing. What do you sugest? Any ideas? It works fine but can not see clock or radio station. No display at all!!
There are two 3mm white LEDs inside the face-plate that need to be replaced. Remove the face-plate and turn it over. Remove the 4 screws in the corners. Un-snap the plastic back off the face-plate. This exposes the back of the printed circuit board. Pull the volume knob off the front of the face-plate. You may need to use a small screw driver to gently pry it up. Flip the face-plate back over and remove the one screw that's holding the printed circuit board in. Separate the printed circuit from the front of the face-plate. Be careful to not lose the spring for the push pin. Flip the printed circuit board over and you'll see a raised metal box surrounding the display. The one end of this metal box is covered in black tape. Remove this tape to revel a small cavity in the side of the metal box with two 3mm white LED in it. These are the 2 LEDs that need to be replaced. This cavity is so small there's not much working room. Note that the positive terminal for each of these LED is on the left and the negative terminal is on the right. Rather than un-soldering the old LEDs I found it easier to use a small pair of diagonal cutters to just cut their leads and then pull them out of the cavity. Leave enough of the old leads sticking up to solder the new LEDs to. Trim the leads of the new LEDs to the proper length, slide them into the cavity one at a time and solder their leads to the stubs of the old leads. Make sure you get the polarity correct. Put everything back together and you should be good to go. I hope this helps you out.
Dec 20, 2009 | Dual XDM-6820 CD Player
My 97 Licoln Town car 4 way flashers, turn signals and brake lights(except for the center inside lite) stopped working. Fuses look good and bulbs look okay. When the lights are turned on the front side...
Replace both lights at the back of your car. The fact that you have steady non-flashing lights at the front and no lights at the back is a troubleshooting tool to let you know the back lights are bad.
Dec 19, 2009 | 1997 Lincoln Town Car
I just bought a Dual XDM6820 and installed it myself into my 2000 Toyota Rav4. The unit worked great for two days. Then I went on a road trip and the unit blew a fuse. I replaced the stereo fuse and the...
If the cd's come in and out fine then it has something to do with key wire (red) . I try and always use and a adaptor harness when installing aftermarket decks. Make sure your wires are well inulated and not pinched when deck is "in its place".
Jul 21, 2009 | Dual XD7600 CD Player
CD will not eject from Dual XDM6820 in-dash CD player
you are probably better off just replacing the deck. there is a plastic piece in the dvd mech that breaks and can only be repaired by sending it to dual to be repaired.
Jun 12, 2009 | Dual XDM-6820 CD Player
I have no display lights on my dual xdm6820 car radio. It does work but I can't see any words or graphics on the front of the unit. Can you tell me what is wrong?
if you have connected all the wires correctly you probably have a faulty dash,
If it is a removable face take it off and clean the terminals and re connect.
Hope this helps
May 07, 2009 | Dual XDM-6820 CD Player
My dual xdm6820 doesnt turn on and theres a red binking light behind the face plate next to the reset button
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Mar 24, 2009 | Dual XDM-6820 CD Player
Car Audio & Video Logo
42 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
