Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
As soon as i push play, something seems to hold it from going into motion, but releases when i push stop.
  • Audio Player... Master
  • 1,267 Answers
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
skywavebe@sbcglobal.net
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Posted on Oct 31, 2012
SOURCE: i need a service/owners manual fora tascam 38 reel
they are available on ebay, but not free.
Posted on Mar 07, 2009
  • 11 Answers
SOURCE: ''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Posted on Apr 13, 2009
Crustacio
  • 3 Answers
SOURCE: BOTH doors jammed on TC-WE605S
Some tape decks are belt-drive. If the belt is worn, it will either break or jump the cog and you will experience these kinds of problems. That's what happened with my Sony ES deck recently and I couldn't even eject the tape until I got the belt replaced.
Posted on Jul 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: I push play and it stops after 2 seconds, same
Is the tape actually moving when you initiate transport commands? Most machines are smart enough to know something isn't moving when it should be. That it fails in BOTH FF and REW suggests the reels aren't moving to take up slack. Cheap machines use glorified rubber bands as drive belts for the reels. Without specifics re: make/model we can't get too precise with an answer. I'd have a pro look at it.
Posted on Feb 15, 2010
  • 141 Answers
SOURCE: when i push play nothing happens then the deck
It sounds like the main drive belt is stretched and slipping or even snapped. Depending on the ease of installation it could turn out to be either cheap or expensive trip to the repair shop. Perhaps it could even be something you could handle yourself. Make sure the power is unplugged and if the belt is still in place take careful note of which way it runs around the mechanism. I have seen apprentices mark the direction of installation with a marking pen.
Some amount of dismantling may be involved. If you are unsure about tackling this job yourself then please leave it with a tech to handle. Especially if the belt is snapped, you may not figure out which way in reinstalls.
Posted on Apr 21, 2010
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Cannot diengage tape heads . transport will not play or record but will rew and fast forward
The reel motor drive is independent of the head base actuator system.
You may need a new belt for the cam system or possibly a gear depending on what they used in this transport. This is a job for a Technician. I have not worked on one of those recently but have done thousands of other Teac and other brand decks over 40 years.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
Record 8 seconds and stop, same problem when playback, rew or FF.
There is a reel sensor - the spindle of the cassette- fitted beneath with is normally an opto-coupler or a magnetic sensor. when the reel moves it produces pulses that is needed to keep the processor asking the motor to work. A failure of the reel will stop the motor as no pulse is generated.
You need good experience to remove open and check to confirm.
Mar 02, 2011 | Canon ES8400V Camcorder
I recently inherited an A-2340 $ Channel Reel To Reel Steror Tape Deck from my Grandfather who performed multi-track recordings in the 1960's. I have powered it up and all seems to work properly except the...
open the back cover and try to push rew. and fwd. then play and observe what is going on. if there is a ticking sound (eg..tick..tick...tick...tick) then it may be a gear has lost teeth on it. other than that it might be lubrication and belt deteriorating issues. my father in law has a similar one. and thats all that was wrong with his.but to me sounds like mainly lubrication issues, but this mechanism also uses belts for the the auto-reverse by flipping the head block around. This belt
will also need changing, and the head block
removed and taken apart to lubricate.
hope this helps
May 10, 2010 | Audio Players & Recorders
I push play and it stops after 2 seconds, same with rew, and fwd
Feb 15, 2010 | Audio Players & Recorders
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Aug 01, 2008 | Olympus VN-3100PC Digital Voice Recorder
AKAI GX-747 does not play or ff or rew. Capstan runs. Stuck in standby forward mode.
My name is Ed, I have the Akai GX-747 Reel to Reel, my problem is when press the play button it engages but the capstan does not spin up to the pinch roller. The reels do not turn.
My e-mail - edward_anderson@comcast.net
Jul 01, 2008 | Audio Players & Recorders
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
Da 38 8 track audio
This is a nice DAT recorder for its time. This unit uses a drive gear system for the FF, RR and the take up reels. Try the ff and rr, if they work, I am quessing there is a bad take up idler clutch assembly.l If the ff and rr does not work, the drive belt(s) are most likely bad. Good Luck
Jun 23, 2007 | Tascam DA-30MKII
121 people viewed this question
 Grubhead
Grubhead
