Question about Brother MFC Office Equipment & Supplies
How can you connect an Apple computer to a Brother MFC-9560CDW as a wireless printer?
Brothers printer without a computer
If this is a Brother MFC-J470DW Inkjet, then it is possible to connect it to a wireless network. If you internet device is actually a "wireless router" as well as a modem (where cable or phone line connects) then you should be able to follow the manual in setting up the newtork on the printer. You may need a phone, iPad or other device that can browse the internet, to register the printer properly and complete setup. There should be a support number you can call for free (check your setup documents). Most companys are anxious to help new cutomers and give them step by step instructions. You can also try http://www.brother.ca/en/customer_care - there are several support option there.
NOTE:
If your internet modem is not a router and only has a wired connection for direct to a PC (a cable that has what looks like big phone jack ends), you would have to add a wireless router instead of a PC. This can be a complicated job, and beyond the scope of this answer.
This printer does support Google print, Apple AirPrint and other network printing (for phones, ipads etc) so once connected, it could be very useful. Brother Canada Customer Support
Jun 03, 2016 | Brother MFC-J470DW Inkjet All-In-One...
I lost the startup disk to my Brother MFC-J270w wireless printer, how do I connect it to the new laptop I bought?
Go to brother.com and they have free downloads for your computer to connect to the printer.
Apr 01, 2012 | Brother Office Equipment & Supplies
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
I'm running Mac OS 10.6 on my portable and the MFC-7840W won't priint. I've update all the drivers but when I try to print, the bluetooth window always says, can't find printer. HELP.
The MFC-7840W does not support bluetooth connection.
It can connect wireless if you have a wireless network or connect wireless directly to your airport on the mac.
Since it is not printing, please follow these steps.
1. Go to the apple icon in the top left of the screen
2. Select System preferences \ Print and fax
3. Right click or control click on the list of printers.
4. Select "reset printing system"
5. Reboot the computer.
6. Go back to Print and Fax (step 1 & 2)
7. Click on the + icon to add a printer
8. Click on the "default" tab and add the printer.
If you do not see the printer in this list, then printer is not connected.
If you do see the printer in the list but you still can not print, you will need to remove the drivers completely and reinstall.
5. Go to Mac HD \ Library \ Printers
6. move the brother folder to the trash bin
7. Empty the trash bin.
NOTE: You may need to reboot the computer before you can empty the trash.
8. Once the trash is empty, reboot the computer.
Now you need to install the following drivers.
Apple drivers
http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriversformacosxv106.html
Brother CUPS drivers
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/003900/dlf003972.html?reg=us&c=ca&lang=en&prod=mfc7840w_all&type2=1&os=94&flang=4&dlid=dlf003972
TWAIN drivers (optionnal for scanning)
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/dlf/000000/003900/dlf003973.html?reg=us&c=ca&lang=en&prod=mfc7840w_all&type2=1&os=94&flang=4&dlid=dlf003973
Thanks,
Pat
Apr 10, 2010 | Brother MFC 7840W Printer
Brother MFC-9440CN Laser Printer how do i set
The only real way to make this printer wireless, is to connect its ethernet port to a wireless router and via the router, send jobs to the printer wirelessly. hope this helps. Cost is about $60-$70 for the router.
Apr 03, 2010 | Brother MFC-9440CN Laser Printer
Wireless printer problem
Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
Mar 28, 2010 | Brother MFC 7840W Printer
Brother printer mfc 240c
no. you should buy a mfc 440cn / 465cn or better -if wireless- a mfc 865cw
May 15, 2008 | Brother Multi-Function Center MFC-240C...
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
