Need registery cleaner
My PC is running at snail speed. Is a register cleaner the way to go? If so what do your recommend?
  • jofitz60 Jan 07, 2009
    Ziriffa did an outstanding job. His answer was just what I needed. Thanks.
  • 827 Answers
You have to be careful with all these 'Registry Optimizers' you see advertised, most of them make more problems than they resolve.
I recommend first downloading and installing nCleaner, and doing a Clean System, then a Clean Registry with that.
Also download Spybot, install, run, download updates, scan for problems, fix selected problems, press the immunize tab, click Immunize, reboot.
After that run Disk Defragmenter.
Your system should be running a lot faster. I would recommend that you keep 15% of your hard drive's memory free at all times, in order that the system has enough resources to work with.
Hope (and know) this helps :)
Chris (ziraffa)
Posted on Jan 03, 2009
  • chris grams
    chris grams Jan 07, 2009
    Hi again,
    You're welcome, glad to help!
    Chris (ziraffa)
Snail facts for kids
  • Land snails secrete mucus to facilitate locomotion and reduce the friction against the ground.
  • Snails try to get a diet that is full of calcium to keep their shells thick and healthy.
  • Land snails have microscopic teeth! They are contained in a structure called the radula and that is composed of rows of them.
  • The "cone snails" a family of sea snails is venomous and some of them are fatal to humans!
  • There are around 600 different species in the family of "cone snails".
  • There are around 30 humans killed by cone snails, that have been registered.
  • The sea snails breathe with gills, the land snails breathe with lungs while some species of freshwater snails breathe with lungs and others with gills.
  • Several species of land snails are used in the cuisine of several countries and they are considered a delicacy.
Aug 17, 2014 | Pets - Others
5 Ways to Speed Up PC
Are you fed up with your slow PC? Well you can Speed Up your PC by 3 times. In this post you’ll find some of the most significant ways to speed up your PC. For your convenience, I ’ll split this post into 2 parts.
1. Automatic Ways to Speed Up PC (Using PC Speed Up Softwares)
2. Manual Ways to Speed Up PC
Automatic Ways to Speed Up PC You can use a PC Optimizer Tool to automatically boost the Speed of your PC without the need to worry about the manual ways of doing it. These tools will automatically find and fix upto 99% of your PC errors by optimizing the Windows registry, cleaning up junk files, removing unwanted items from the start up etc. This can speed up your PC and Internet speed by upto 3 times. Here are some of the best PC Optimizer Programs that I recommend.
1. Perfect Optimizer
2. Registry Easy
Using a PC Optimizer is the easiest way to speed up your PC. This is because, most of the performance tweaks such as Registry Cleanup cannot be done manually.
Manual Ways to Speed Up Your PC 1. Free Up Disk Space to increase the speed of your PC
  • Remove temporary Internet files.
  • Empty the Recycle Bin.
  • Remove Windows temporary files.
  • Uninstall Programs that you no longer use.
2. Periodically Perform Hard Disk Defragment. This can Speed Up your PC significantly.
3. Clean Up your Registry (Highly Recommended)
Cleaning Up your Windows Registry is very much necessary to speed up your PC. Unfortunately you cannot do this manually. You have to use a Registry Cleaner to do this. Here is the best registry cleaner on the web.
Registry Easy
A complete review of registry cleaners can be found at Registry Cleaner Comparison
4. Clean Up the browser cache to Speed Up your Internet.
5. Install a good Antispyware software
Spywares can really hurt the performance of your PC. So, install a good anti-spyware to protect your PC from spywares and improve the speed of your PC. I recommend the following Antispywares to protect your PC.
1. Spyware Cease
2. Nodware Anti-Spyware
Which is the Best Way to Speed Up my PC? (Auto or Manual) The best way to speed Up your PC is by using a PC Optimizer such as Perfect Optimizer or Registry Easy. This is because, manual ways can only perform 30-40% of the tweaks to improve the speed of your PC, but the most important aspect of the Speed Up process such as Registry clean Up and other advanced performance tweaks can only be done using a PC Optimizer software. So if you are serious about improving the speed of your PC, then you need to use a PC Optimizer.
AKPC_IDS += "1167,";Popularity: 9% [?]
on Mar 30, 2010 | Computers & Internet
Computer cleanup, a cleaning process overlooked
Get a good registery cleaner, one i recommend and is free is (Glarysoft Utilities) you go to it will speed up your computer and it cleans it.....its free....highly recommend it.....use it at least once a week to keep your computer running like new.....
on Jan 06, 2010 | Computers & Internet
When i start my acer 5570z laptop error window appears, could not load or run c:/users/acer/local specied in the registery. make sure the files exists on your computer or remove the reference in the...
Might be caused by malware . Google malwarebytes download and run update then scan your system. Just post here if problem persist i would gladly help you.
Jul 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
My window xp turn to slow
well thats windows problem, and the problem is normal, and its because to much uneeded files are still there in ur drive or in ur registery, taking memory and space, so get some registery cleaners progs (ccleaner), and clean all your old unneeded files.....
Apr 30, 2010 | Microsoft Windows XP Professional With...
The vaio runs slow when trying to get to the
download and install Tuneup utilities and fine tune you pc for registery errors. use all the features available there for speeding up the laptop.
You can even speed up / optimise your inetrnet connection there.
chose the correct speed depending upon the max speed provide to you by your service provider.
Dec 07, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
My computer is running out of free disk space. ive deleted several items but that doesnt seem to free much space up.
Get CClean and run it ...
Run the registery cleaner as well.
defrag yor hard drive
Things will improve for you
have scan your computer for additional guidance.
Oct 24, 2009 | Acer Aspire 5610 Notebook
Xp very slow closing down just lately
This could be due to a registery that is cluttered. A Free program to clear unneeded junk in the registry is Eusing Registry Cleaner....Google it. Another Free program to speed things up is SPEEDITUP . It frees up RAM which will speed up everything in windows including shutdown. If you have a lot of programs running in your tool bar you might shut them down manually before exiting windows.
Oct 12, 2009 | Microsoft Windows XP Professional With...
Hi,I am trying to Uninstall some unwanted programs and I get a field saying Setup.exe has stopped working ! but only on a few stuborn programs I have uninstalled others OK.I'm running Vista Home Premium...
The register cleaner is the reason the programs wont un install. You need to roll back the registery to correct the problems. If you didn't create a backup prior to running the clean there is not a simple way to correct the problem.
Aug 31, 2009 | Toshiba Satellite P300-ST3712 Notebook
Computers & Internet Logo
David Payne
David Payne
