Question about Cameras
I have a Zoom Q3 video record with a broken lcd
I have a Zoom Q3 video record with a broken lcd screen. What is the correct screen to replace it with? Where can I find one? I tried contacting Zoom directly, with zero results. I can replace the screen myself, I just need a replacement screen.
3 Suggested Answers
SOURCE: my olympus fe 210 has the lcd screen broken, I would like to fix it by myself, how to replace it?
Hello Fabio,
You can find the replacement LCD screen for Olympus FE210 here:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Olympus
Posted on Jun 01, 2009
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
Why zoom g2 point blinking ?
There is damage/burnt at Transistor Q4 or Q3 or both. Usually followed by R8. Replace it.
Q3 = BC337 (SMD marked as 6C) NPN.
Q4 = BC327 (SMD marked as 5A/B/C/D) PNP.
R8 = 470 ohm (SMD marked as 471).
May 06, 2014 | Zoom G2 MultiEffects Guitar Pedal
VIDEO MANAGEMENT
How old is this video camera?
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
How to eliminate virus in my zoom q3hd
Have the memory card SD/HC checked by any antivirus software.
Format and clear if necessary.
Rest assured. There CANNOT be any virus in your Zoom Q3HD.
Apr 27, 2014 | Zoom Q3HD 1080p Handy Video Recorder
The screen does not display any iinfo when on
The problem is related to LCD screen. I am currently looking for a replacement screen to do the repair myself. If you come across a part# for R16 LCD, please contact me.
Apr 20, 2013 | Zoom R16 Multitrack Recorder
I have a Zoom q3 HD camera and it does not hold a charge with the double A battery's. plus it sticks and flashes after starting it up!
Hi the batteries are not good anymore, they have probably been left unused in the camera for a long time. Get new ones, or if you have replaced them, then the charger is not supplying the correct voltage to the batteries.Did you ever drop that camera by any chance?If so you could've damaged the internal hard drive.That could also cause the problem...Regards
Apr 19, 2013 | Video Cameras
Zoom Q3 ERROR 35390
I have the same problem.. Doe you have a solution yet?
Greeting from holland
Jul 20, 2012 | Zoom Q3 Video Recorder
Power button broke on zoom q3
There is a design defect in the zoom Q3 video/sound recorder. The power button is tiny and only held by three finite solder points that cannot take the regular force of one pressing on it. The solution is simple and permanent. Since the Samson tech Zoom Q3 comes part easy you have access to the part. The power switch falls of and stays inside. Get a fine tip soldering iron and resolver it, but the real trick is to put some liquid plastic support in behind the power switch and around it so that it will no longer be affected by the force of pressing it on and off. Video here: http://youtu.be/SwHJ9b6yNrc
Jul 16, 2012 | Samson Technology Zoom Q3 Handy Video...
Windows media player won't play my videos because the extention "mov".
Try VLC Media Player, which is free software that is compatible with many different types of videos. The link to download VLC can be found here: http://www.videolan.org/vlc/.
Nov 24, 2011 | Samson Technology Zoom Q3 Handy Video...
Black and white screen ,when on recording mode
i am not sure that i solved that problem but last night i was trying to solve this problem , there was a lamp close to me . i focus the lam and zoom in and zoom out the handy cam. i was wonder that it works great. but i am still not satisfied because i dont know what is the problem ? and it can be happpened again. If somebody really knows this problem kindly tell me . i appriciated.
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
Lcd
hi, i too had the same problem, try to zoom in and out after power on and check any image on lcd. This is due to zoom unit movement had broken the contacts with the sensor. Mine got corrected in pentax service with $40(india) sreejith
May 06, 2007 | Pentax Optio 30 Digital Camera
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
