Question about Garden
How do I know what carb kit to get for a 5hp Briggs and Stratton motor on a Masport Rotary Hoe?
Went to local shop for carby kit, they said their are 4 options, cant find any more details on motor?
  • 430 Answers
Take the model, type, and code number from the motor with you to the local shop and they should be able to identify the proper kit.
The numbers are usually stamped on the flywheel cover. either on top ( by the head) or on the side or on the front directly over the flywheel fan.
Posted on Nov 05, 2012
  • hinesfamily5
    hinesfamily5 Nov 06, 2012
    Thank you, the label was gone but did find a row of numbers, local shop told me they meant nothing but further investigation on internet told me i have a 130 202 model B&S , thanks for taking time to reply!! Have now replaced diaphragm
KMusselmann
  • 247 Answers
SOURCE: I'm looking for the reverse belt routing.
Just take the old belt to a auto parts store and they can match it for you. If you dont have the belt take a piece of twine and put it around the pulleys
to make a template so to speak. Then take that to the auto parts store. Hope this is a FixYa. Pls rate the answer.
Kurt
Posted on Mar 21, 2009
  • 97 Answers
SOURCE: Unable to get the tiller to start, has new spark
take fuel line off carburetor and see if you are getting fuel through the line.Is the fuel fresh?
Posted on Mar 25, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
panilling9
  • 284 Answers
SOURCE: Briggs engine identity problem on craftsman tiller
sears.com
enter your mod#143.707012
Posted on May 26, 2009
jdlipscomb41
  • 157 Answers
SOURCE: need info. on old montgomery ward powerkraft
if it has old belts pull them off and go to any parts store for them to be matched up. if not get you a piece of good strong string and run the string around where the belt goes and measure belt lenth that way.
Posted on Oct 26, 2009
Fix my Masport rotary hoe Briggs & Stratton 206 cc. I/C serial commercial use.
as you cannot describe the problems take it to a mower shop for repairs
Jan 30, 2017 | Briggs & Stratton Garden
Briggs &stratton 11 hp
timing issue. Remove the flywheel to see if it has "spun" from the keyway. If the motor doesnt run at all but just backfires thru the carb, it could also mean really bad intake valves, but I would definitely check the timing first
May 14, 2014 | Briggs & Stratton Garden
Wizard rototiller model 5hp. Briggs. Not getting fuel somehow. Fixed carberator. Spark plugs cleaned everything out... what could be the issue
is it a bowl style carb and you cleaned it is it a diaphram style and you replaced the diaphram ?the older 5hp briggs engines would run fine if you started it with carb cleaner some leaked head gaskets and could create enough vac to draw in the fuel
Mar 28, 2012 | Briggs & Stratton Garden
I have a masport5 rotary hoe I do not know what petrol to use
If this engine is a Briggs & Stratton 3.5HP then is is a 4 stroke motor that uses straight petrol. For this engine specification check out this WEB site.
http://www5.briggsandstratton.com/au/en/our_products/engines/product.aspx?parentCat=2&curCat=21&pId=116
Dec 29, 2011 | Car Audio & Video
I've been trying to start my briggs & straton Masport lawn mower, after it was sitting idel for over a year. Replaced oil ok / added new fuel / spark working, however it dies after fisrt kick...
You probably still have old fuel and water in the carb itself.
take off the air filter and look for the bowl screw or clip *(depending on model)
You can drain the bowl and let some clean fuel run through the gas line as well.
If the new fuel was last years you might want to check the gas can for water as well.
I work at a mower shop and at this time of year we do a lot of these kinds of repairs.
Fuel today just isnt kind to equipment that sits around for any length of time.
Mar 27, 2011 | Briggs & Stratton Briggs Stratton...
Looking for a manual on a masport rota hoe 5 hp briggs and straton. machine is approximately 25 to 30 years old
Your best bet at possibly getting a manual are in the 2nd link below for the rotary hoe.
Phone numbers AU and NZ
http://www.masport.co.nz/CONTACTUS/CustomerServices/tabid/679/Default.aspx
Contact Masaport directly here: (form)
http://www.masport.co.nz/SUPPORT/ImageRequestForm/tabid/664/Default.aspx
You can use the Distributor locator here:
http://www.masport.com/DISTRIBUTORS/DistributorLocator/tabid/182/Default.aspx
There is one site that is a pay site that has ONE resident Masport person. I can not list it here but has outdoorsking in the address. FixYa TOS thing.... (web search!)
As far as any engine manuals. The engine type model and series are stamped into the air shroud not far from the spark plug wire. http://www.briggsandstratton.com Type in your engine model type series and you can download you parts and engine manual.
Thanks for Choosing FixYa.
Kelly
Sep 20, 2010 | Garden
Masport rota-hoe
try this forum, bruce there seems to be the man to know about ur machinery, he could more than likely help
http://www.outdoorking.com/forum/ubbthreads.php/ubb/showflat/Number/5827
Dec 08, 2007 | Computers & Internet
Garden Logo
190 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
