Question about Dell Office Equipment & Supplies
White vertical lines on dell 1410x projector - Dell Office Equipment & Supplies
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
projdoc
  • 2236 Answers
SOURCE: White Vertical Lines on screen from a JVC projector
bad pcb. get your money back.
Posted on Aug 07, 2009
projdoc
  • 2236 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
The image has little black and white dots everywhere. What is the problem?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.we supply the DMD chip
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 04, 2016 | Dell 1410X Projector
The screen shows multiple tiny dots. (stars)
Are they sharp and defined, or 'blob'-like? If they are sharp, that would indicate a faulty DLP block (not worth repairing, unless under-warranty.) If they're more 'blob'-like, it's probably just dust in the optical block. That can usually be remedied by removing the lamp, and blowing-out the unit with an air compressor. Canned air won't do the job, as there's not enough pressure.
Apr 26, 2013 | Dell 1410X DLP projector 2700 ANSI...
What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
Dell 5100mp dlp projector - white vertical lines evenly spaced
Sep 02, 2009 | Dell 2400MP DLP Projector
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
112 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
