Kyocera FS1118 mfp ERROR 2101
SUDDENLY I GET THIS ERROR AND CANT SCAN TO MY FOLDER IN MY MACBOOK
n25an
  • 622 Answers
SOURCE: Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Posted on Dec 24, 2009
Daniel S
  • 4323 Answers
SOURCE: Kyocera FS1118, error code C6400, how do I resolve
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Posted on Jun 21, 2010
shawn38
  • 200 Answers
SOURCE: We have a Kyocera FS1118.
I have the setup instructions posted, click on the link below and follow those instructions. If after following those instructions you are still having a problem feel free to contact me.
http://gfbm.net/selfhelp_kmacopier_scan_to_email_setup_command_center.htm
Posted on Jan 22, 2011
  • 64 Answers
Look at http://www.copytechnet.com/forums/kyocera-mita-copystar/16737-fs1118-c6400-error.html
for the answer.
Posted on May 06, 2011
  • 167 Answers
SOURCE: My kyocera FS1118 MFP
C6400 indicates that the engine board is not recieving the correct signal.
I would suggest that you turn off the machine and ensure that the cable that runs from the document feeder at the top rear of the machine into the connector on the rear of the machine (if fitted) is securly tightened.
You can also try turning the machine off at the wall for 10 minutes.
If this fails you will need to call out a technician.
Posted on Jul 22, 2011
We are using KM 4050. Everything is fine, We can print, copy, but we cannot scan to email. It started yesterday. I check all the setting, cable, I even change to use gmail SMTP server. it still gives me...
You cant can to email using gmail server. they have hundreds of different servers. would reccoment setting up scan to folder either to a shared folder on your server or straight to your c drive if needing some confidentiality
Oct 16, 2013 | Kyocera Km-4050 With Feed, Finisher, Bank,...
My kyocera FS1118 MFP displays C6400 error. Can you help me?
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Getting error code 2101 when scanning a document into our kypcera mfp cs 1820. What is the error and how does one fix it?
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Mar 02, 2010 | Kyocera Copystar CS-1820 Black and White...
Jan 23, 2009 | Kyocera FS-1118 Printer
ERROR CODE 2101 WHEN TRYING TO SCAN
Oct 30, 2008 | Kyocera Copystar CS-1820 Black and White...
KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Oct 14, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
k24674
