Question about Plumbing
Indicator light doesn't work on my brita faucet filter
2 Suggested Answers
  • 34 Answers
SOURCE: indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
Posted on Feb 04, 2009
Tip
Brita Memo Replacement Unit failed then order a FREE replacement !
Create an account at Brita then go here you will receive you new Brita Memo Replacement Unit within 10 days.
https://www.brita.net/uk/replacement_parts.html?L=1
Usually the battery in this unit will last about four years however if you register your details with a valid email all BRITA products will come with a 2 year manufacture guarantee... but should any part of it break, we will send you a replacement part absolutely FREE
Don't bother trying to replace the CR1616 battery yourself it is a sealed unit and once the seal is broken you can replace the battery but it will fail very soon with steam ingress even if you superglue it.!!
USER REGISTRATION required valid e-mail
BRITA MEMO how it works
CARTRIDGE REMINDER via email every four weeks
Here is to cleaner water in your kettle and the means to know when to change the Filter.!!
on Mar 02, 2010 | Brita 35516 Pitcher
Brita faucet filter adapter is stuck in my faucet
It sounds like the adapter was screwed in at an angle. This causes the threads to cross in turn making it near impossible to unscrew. Since it is plastic I recommend buying a new adapter. I know it's unfortunate, however it is a lost cause.
Jan 23, 2014 | Clorox Brita Water Filter For Faucet White
Touch sinking fix
It sounds like you may have a built in filter in the faucet. The red may indicate that it is time to change the filter, but more than likely it is an indicator for low batteries which are located in the cabinet below the sink. Either change the filter, or change the batteries.
Jul 27, 2013 | Plumbing
Brita filter leaks water
Great video! Have you tried removing the filter from the faucet and checking to see whether something got cracked during installation? It may be necessary to simply replace the whole thing
Oct 12, 2012 | Dishwashers
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Indicator light for Brita filter not working
1-800-24-BRITA (US)
Jan 30, 2009 | Plumbing
Brita faucet filter will not stay on faucet
Want a free adapter and patient enough to wait for a couple of weeks to get them?
"To receive a special adapter free of charge, call 1-800-24-BRITA or 1-800-387-6940 (CANADA)."
Call the number above and a voice prompt will give you instructions on how to get your adapter for free. 2 weeks might be too long but the best thing is it is made of stainless steel/chrome and it comes in 3 different kind of adapters with rubber washers.
Jan 19, 2009 | Kitchen Appliances - Others
Plumbing Logo
1,275 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
