Question about Canon Office Equipment & Supplies
I do not know where to change the ink
Where is it located on the printer
  • 3 Answers
Que modelo de canon?
Posted on Oct 30, 2012
Hi I have a canon mp210 pixma printer and every time I print it brings an error up that the waste ink absorber is almost full, do you know how I solve this?? thanks
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 11, 2011 | Office Equipment & Supplies
Waste ink pads - need counter re-set
download "SSC Service utilities" software and try with this program
Dec 21, 2009 | Epson Stylus Photo R320 InkJet Printer
Can you let me know where to locate the ink cartridge on the hp 1410,i cant find it to change it
Turn the printer on then open the front cover.The carriage with the cartridges will move to the center and you'll can change the cartridges.
Nov 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
Need to change ink don't know where ink is located
this is the complete Manuel INCLUDING how to put/change the ink cartridges and diagrams so you know where it is--- http://h10032.www1.hp.com/ctg/Manual/c00461370.pdf
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
How to change the ink cartridge and where is it located
Here is the user guide, see page 113 for instructions on how to replace the ink cartridges:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5460CN_5860CN_EN_277.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 13, 2009 | Brother MFC-5460CN All-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cannot locate ink catridge for HP PSC 750 printer
With power on, simply lift up from the hatch located on the front of the unit. The ink jet will slide to the middle position.
Mar 27, 2009 | HP PSC 750 All-In-One InkJet Printer
IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
Mar 07, 2008 | Canon I990 InkJet Photo Printer
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
11 people viewed this question
old marine
old marine
