Question about Samsung CLP-500 Laser Printer
Black stripes I have a Samsung CLP-500. On the prints are black stripes (vertical, from top to bottom). Can someone tell me where they come from?
  • Eternalbunny Dec 01, 2007
    My Samsung CLP-510 printer is a year old and this problem started occurring around the 6 month mark. I've printed a total of 2500 copies. When I print black and white, a black, vertical stripe about 1 inch thick appears down the left side of the paper. When I print colors, the exact stripe appears colored. Occasionally it goes away, but 90% of the time it reappears. What is the problem/solution???? Help.
  • Anonymous Mar 31, 2014
    stripes when printing
I too have "stripes" on my printout. Kinda looks like a giant barcode from top to bottom (portrait) but the stripes are not sold black. almost 1/2 tone.
Anyway, I noticed there were what appears to be matching bars on the drum. Kinda like dust streaks. Opened up the waste chamber of the drum. Lots of "dust". Cleaned everything. Re-installed. Same problem.
Pulled the drum and the dust streaks are there.
Next I dis-assembled the drum.
The only thing that I could see that was cleaning the drum was the semi-hard rubbery strip in the waste chamber. Cleaned it and the opposing flimsy plastic strip.
Test print one page .... dam streaks are back.
I check the waste motor assembly and it was not clogged.
Now what?
mjoyce at mindspring.com
Posted on Sep 19, 2008
    Novelist:
  • 217 Answers
I've seen this before on CLP-500 CLP-510 and was caused in one case by a build-up of toner on a wiper blade in the transfer belt asembly, and in the other, a build-up on a wiper blade in the drum assembly.
If you can borrow (known good) Transfer Belt Assembly and Drum Unit, you'll be able to substitute one at a time and see when the fault disappears.
Not usually an end-user repair (taking a drum unit or transfer belt assembly apart), but there is little to loose if the print quality is unacceptable anyway.
Wiper blades to examine are those around waste toner augers. One (at least) is likely to have a crusty lump on it.
Take care - lose waste toner can cause other problems.
Posted on Nov 12, 2007
    Scholar:
  • 121 Answers
There has probably been spilled some toner inside the printer. You might be able to have it cleaned. It also might just wear off, but that will take some time. If the printer has toner cartridge with a drum inside, changing it might help.
Posted on May 18, 2007
I have a Samsung CLP-300 Laser Printer. I am getting two vertical voids in the black printed pages. I've installed a new black toner cartridge, but that did not help. How can I eliminate the vertical...
If your printer prints like this:
slamfix_13.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 22, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP 300 wont print black
you need to clean image unit
if you dont have any expertise dont do it
Dec 14, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Apr 04, 2009 | Samsung CLP 300 Laser Printer
CLP-300; new black cartridge; prints, results are grey,
I suspect the problem is common. The Imaging unit requires a Black developer to be replaced. you may approach samsung service center for this.
Jan 01, 2009 | Samsung CLP 300 Laser Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Faded Laser Printer
LASER UNIT NEEDS TO BE CLEANED IN CASE THE TOP GLASS THE SAME ASSEMBLY IS CLEAN HAPPY FAXING OMNIPRESENT
Sep 15, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
793 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
