Question about Symbol Computers & Internet
Can't connect to internet
  • Jean-Marc Nov 02, 2012
    OK to clarify, this is quite an advance question and who answers this one definitely needs to have a more knowledge then just how to setup a router.I can confirm that the WAN is working properly, I do get Ip and DNS etc. the Lan and WLan is also working properly and I use it as a DHCP server and it does provide the IP to the MU's, the problem that I'm having is that for some reason it wont bridge between the WAN and my internal network even though the DNS is matching the one supplied by my ISP
Bought an Asus K55VJ-SX218H notebook for college & can't connect to their wireless Internet. We've also tried connecting using cable with no luck. It connects to my home wireless but not t
You need to contact the college's IT support to get the college's wireless router configuration settings so you can configure your laptop's wireless with these settings.
Mar 04, 2013 | ASUS Computers & Internet
Red light on modem's internet
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
Recheck and correct the Ethernet connection between your PC and the router device.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
Could not brows internet from aircel 3g roaming sim
you have to activate your roaming data from setting or mobile data option to start internet
Jun 09, 2017 | Cell Phones
Coby Kyros MD1042 will not connect to Internet
I hate to be rude but WEP was broken several years ago. Use WPA or WPA2 or (best of all) a wired connection.
Make sure you have the latest firmware for your router and the latest drivers for your network card on the PC/laptop or console.
Sep 09, 2012 | Computers & Internet
How to connect new devices to Thomson router (TG585 v7)
Using a command prompt and telnet:
Type in telnet 192.168.1.254 and hit Enter. If this doesn't work, then you don't have Telnet installed and will need to go to Start ? Control Panel ? Programs ? Programs and Features ? Turn Windows Features on or off ? Ensure TELNET CLIENT is checked and click OK.
When prompted, the default username is Administrator (case sensitive) and the default password is either blank or the serial number of the router (case sensitive):Click to open image
Type in "connection unbind application=SIP(TCP) port=5060" (without the quotation marks) and press Enter. If you get a 'unknown command' message returned once you press enter, then type in: "connection unbind application=SIP port=5060" (without the quotation marks)
Type in "saveall" and press Enter to apply and make this setting permanent
Feb 27, 2017 | Computers & Internet
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
Changed connection and modem to 100 Mbps. No wireless connection from router. Tried wired connection. No go. Router does connect..all lights green. Laptop sees the connection but no internet access.
Improve the Fixya.com experience for everyone by voting!
Subject: No wireless connection from router cannot connect to the Internet.
Solutions: Straight Connection, Windows Connecter and Microsoft Fixit
Discussion: I'm going to provide you with three solutions and between them you should get online. However, you should be advised that in order to fully analyze and correct any difficulties you're having, we should be chatting or on a telephone connection. All I really know at this point is that you can't connect to the Internet through your router.
I'm going to give you three FREE general fixes and let's hope that one of them will work for you. If not, then we have to chat.
Now, let's see if I can help you.
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online.
However, if the first solution doesn't get you connected, do the following:
• Click on tools again.
• Click on 'Diagnose Connection Problems'
• and follow the instructions.
The second suggested solution is to use the Setup Wizard. It seldom works for me but you might have more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
The third solution requires an Internet connection. I'm going to pass on to you a FREE and hard to believe program from Microsoft called Microsoft Fixit! I have no idea why this little program hasn't been advertised but then I don't own their stock.
Just click on the following link and your problem should be solved: Download Microsoft's Fixit
You'll see the following areas in which Microsoft Fixit can solve software , hardware and just about every other problem you may incur. They are:
Top Solutions Windows Internet Explorer Windows Media Player
Entertainment Office Other
I suggest that you try top solutions and 'automatic' before exploring the other titles.
Be a hero and fix your friends' computers; just don't tell them how you did it! That will be our little secret.
All the best
Ben
Jul 23, 2011 | D-Link DIR-615 Wireless Router
My laptop has had a complete memory boot and i can not get my wireless connection back on. How do i correct this problem/ i am using a ethernet cable at the moment to get connection to internet. Thank you
Let's see if I can help you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
All the best
Ben
Jun 18, 2011 | Acer Aspire 5315 Notebook
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 18, 2011 | Computers & Internet
I just got att dsl service. I have four green lights on the modem and wireless is working. I can access wireless on my phone and laptop in the house. When I open IE, all I get is "cannot display...
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 03, 2011 | AT&T High Speed DSL Modem
Computers & Internet Logo
32 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
