Question about Proform Exercise & Fitness
Proform 6.0 CE Elliptical squeaking
Squeaking from under the cover drives me nuts. I don't know how to fix it.
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: my proform 10.0 ze elliptical has developed a
It sounds like the sleeve bushings maybe dry usually penetrating oil will take care of this problem. If not you may need to replace bushing then go to iconfitness.com to customer service then to replacement parts you'll get part# and Pricing
Posted on Feb 28, 2010
bwinton
  • 83 Answers
SOURCE: I never recieved a manual from sears when I bought
Go to this site (http://www.iconservice.com/CustomerService/manuals.do?dr=PF) and put in the model name or number and it will give you a link to download the manual.
Posted on Mar 24, 2010
  • 5370 Answers
SOURCE: Have a diagram for the
The 25 amp fuse is for radio amplifier.Click this link for fuse and its slot diagram:--- http://howtobyme.blogspot.com/2011/08/fuse-box-diagram-for-2000-jeep-grand.html ---------- This will help.Thanks.Helpmech.
Posted on Aug 25, 2011
ercupa190
  • 12223 Answers
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 30, 2011
Right pedal makes clicking noise from the rear of the machine
Remove the right side shield and watch it operate and you'll see what's clicking. You're manual shows you how to remove the right side covering.
Jan 29, 2014 | Proform Pro - Form Rear Elliptical 14.0 CE
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
1) adjust magnet with the bolt looses with a wrench, tight very well.
2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
God bless you
Jul 24, 2012 | Exercise & Fitness
I have a proform 14.0 ce and the menu buttons dont work
`1) tight the ribblon cable from keypads very well, + tight the wire connector from display board+vs lower board see the block diagrama
2) adjust the reed swithc, clean, and tigh the connector well.
God bless you
Jun 24, 2012 | Proform Pro - Form Rear Elliptical 14.0 CE
Elliptical is hard to pedal
see the next video:
sincerely. God bless you
Apr 30, 2012 | Proform 405 CE - Elliptical Machines &...
My proform 10.0 ze elliptical has developed a repetitive squeak in the rear drive...any ideas for a quick fix?
Feb 22, 2010 | Exercise & Fitness
I have an older proform elliptical and the battery cover cracked.
Go to FitnessRepairParts com and type in your exact model number in the search box at the top to view the parts list for that model. You may be able to find a cover there. Or you can contact support if you can't find your exact model number, they are very helpful
Feb 16, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
388 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
