Question about Lexmark X75 All-In-One InkJet Printer
I have a Lexmark X75 and it will not work. i just got new ink. the status light is blinking and I don't know what's wrong with it. There is paper and ink. Please help.
  • 685 Answers
Try to unplug it for a little while this will reset it
Posted on Jan 04, 2009
Can no longer print
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Dec 12, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 not working - flashing power and status light - no paper feed.
  5. Unplug and re-plug the printer into the power source to reset it.
  11. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Cant make it work!!!
Unfortunately with the X75, a ‘flashing’ Status LED indicates one of two conditions:
  1. The unit is out of paper (or thinks that it is out of paper)
  2. A problem in another area (I know, not very helpful, but that is straight from the X75 User’s Guide)
I did find a reasonable Trouble Shooting guide in the X75 User Guide and not wanting to plagiarize the Lexmark document, I found two URLs that point to the actual document:
User Guide:
http://www.memphys.sdu.dk/facilities/computing/documentation/lexmark-x74-x75.pdf
http://support.lexmark.com/index?locale=EN&page=product&segment=SUPPORT&userlocale=EN_US&productCode=LEXMARK_X75&focusedTab=TabListPanelChanger_PUBLICATIONS
As this unit was recently relocated, the method in which it was relocated could help explain where the problem may be.
  • If the unit was carried by hand and carefully, then there could be a seating problem or loose hardware inside the unit enclosure.
  • If the unit was shipped by a mover (meaning it was packed and boxed) then the problem could be a broken paper tray sensor, a misalignment of the print cartridges, a misalignment in the print cartridge belt, or something related to the ‘print cartridge position sensors’
Something to consider is that just because there is paper in the unit, does not mean that the sensor logic is functioning properly to report this condition.
I hope this helped,
RojoSho
Jan 07, 2010 | Lexmark X75 All-In-One InkJet Printer
Changed ink cartridge but still shows low status on lexmark all in one x7350
When I had a Lexmark printer last, whenever is inserted a new cartridge I had to go into Printer Setup and tell the printer I had installed a new cartridge...
May 09, 2009 | Lexmark X75 All-In-One InkJet Printer
My Power button is flashing and the status.
Well the issue might be with the cartridges or the printer itself.however, please remove the cartridges from the printer and check whether the light is blinking. If the light is blinking then the issue may be with printer hardware. If the light does not blink, then try installing one cartridge at a time and check on which cartridge instaling does the light blink.
Apr 03, 2009 | Lexmark X75 All-In-One InkJet Printer
Power button and status button on same time
sounds like a possible bad printer driver install. can you reinstall the drivers or try a different usb port?
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Blinking lights on a Lexmark X75
Try taking out the the inks. then try to print then replace one at a time.
May 22, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75
try installing the driver with the machine disconnected from the pc. Is this a new printer, first time install
Jun 21, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
177 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
