Question about Hitachi Televison & Video
Tv won't turn on. All three lights flash in sequence power heat then bulb. The bulb appears to be in tact.
Previously I have replaced the bulb before and only the bulb light was flashing Also last time when I pulled the bulb it was shattered. So it was easy to diagnose that it was the bulb.
  • Hitachi Master
  • 8,617 Answers
I will need the model number of the set in order to assist with the issue as the three lights blinking is an error code which would be different based on which model number TV you have.
Posted on Oct 31, 2012
SOURCE: green light flashes 3 times, tv won't come on
If its not the bulb, I have the same problem
Posted on Nov 22, 2007
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
Posted on May 13, 2007
SOURCE: TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Posted on Feb 15, 2008
premtech
  • 934 Answers
SOURCE: Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
38 Excess Lamp Temperature
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Bill
Posted on Sep 27, 2008
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Sony tv won't turn on, light in standby blink three times
that is a master control board failiure, it is caused by having your TV on all the time, when the TV gets warm, you need to shut it off and let it cool down(that caused your problem) call sony and order a replacement part, it will take you about 20-40 minutes to install yourself.
Jul 19, 2012 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
On my 2006 Audi A6 Quattro, the right rear brake light was not working while braking. When I removed the lamp to replace the bulb, four bulbs were on, and one did not work. Then, four bulbs were not...
BULB SOCKET HAS SOME CORROSION IN THEM NEED SPRAY SOME ELECTRICAL CLEANER CLEAN CORROSION. OR YOU HAVE ELECTRICAL PROBLEM IN THE CONTROL MODULE THAT CONTROLS REAR LIGHTS.
Aug 28, 2011 | 2005 Audi A6
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
TV turned off while watching and will not power up again. The red light appears and then shuts off, no picture at all.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 30, 2010 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
