Replacement projector lamp for sharpVision XG-H440U
  • 17 Answers
SOURCE: Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Posted on Jul 17, 2008
SOURCE: Projector won't stay on
Most projectors have a filter that can be removed and cleaned. Perhaps it is clogged or you may need a new bulb.
Posted on Apr 27, 2009
projdoc
  • 2237 Answers
SOURCE: SHARP XG-P25X PROJECTOR PROJECTOR RUNNING
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XG NV51XE lamp reset
if you get no led on the top, reset the bimetal breaker. take off the top and press the red button on the front of the lamp housing.
Posted on Dec 23, 2009
arthurroger
  • 170 Answers
SOURCE: auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Posted on Apr 23, 2010
I have a Sharp xv-z9000u projector. I recently replaced the lamp; however, I cannot turn the projector on. how do I reset the lamp timer?
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset
Jun 04, 2011 | SharpVision XV-Z9000U Multimedia Projector
How do you replace the bulb in Sharp XG-E3000U
To replace the lamp is pretty simple its located on the bottom of the unit the cover has one screw to remove it the cover. The lamp has three screws to remove it theres a handle to pull it stright out.The internet is a very good place the find a new lamp.
Jan 10, 2011 | Sharp (CLMPF0046DE01) Projector Lamp for...
How to reset the lamp usage for Sharpvision XV-Z1U
Press and hold VOL. DOWN and ADJ. DOWN (ARROW DOWN) while turning oh the main power switch.
Sep 22, 2009 | SharpVision XV-Z1U Multimedia Projector
Sharp XG-E650UB LCD Projector
Absolutely, they are designed to do so. You will need a svideo cable for video if your laptop doesn't have a parallel port for external monitor. Most projectors have svideo and parallel ports to use them as monitors. If using the external monitor option you select the alt/enter buttons to display on projector.
Aug 07, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Won't power up
I had the same problem after I replaced my lamp. You need to hold down the:
On
Enter
Down Arrow
Right Arrow
simultaneously - this resets the lamp counter. After I did that my projector fired right back up.
Nov 22, 2007 | SharpVision XV-Z9000U Multimedia Projector
SHARP XG-E1000UB
the model # you have given is for the bulb, not the projector......
Sep 12, 2007 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
jasbo
jasbo
