Need a replacement tv base for a rca 46WD250YX11
Where can I find a TV base stand for my RCA L26 WD21 TV?
your best bet is going to be someplace like ebay for this item. I do not believe that this would be a standard replacement part from the manufacturer.
Nov 11, 2015 | RCA Televison & Video
Friends gave us their tv when they purchased a new one. It has no base to the tv and we cannot do a wall mount in our rental house. Where can I get a RCA L26HD35D tv base or stand to go in the slot on the...
RCA which is Thompson is the only likely place and you will need to tell them the model number and do not forget the base may not if available come with the bolts that attach it to the set.
Jun 12, 2012 | RCA L26HD35D TV
Is RCA 24V511T digital or analog? Also can I use a universal remote or do I need the replacement for the original remote that came with it? I
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
Sep 22, 2011 | RCA 24V511T 24" TV
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
I NEED A BASE FOR A 42'TV
take down this info:
All RCA Television Support Numbers hours of operation are 9 AM - 9 PM Monday - Friday EST and 10 AM - 7 PM EST on weekends.
call RCA LCD Television Support: 1-888-977-6722
they will help you order a base for your tv
Jan 31, 2011 | RCA L32HD31 32 in. LCD HDTV
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I recently acquired my grandmothers tv = an 2004 model RCA #27F350T and wondering if it is digitally ready for Feb. 19 - we are currently using an outdoor antenna with a booster.
I could not find a "RCA model #27F350T", but there is a RCA model 27F530T, and according to the users manual for that TV, it is not Digital ready. You will need a converter box if you wish to continue receiving antenna based broadcasts. Your users manual can be found at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
Jan 04, 2009 | RCA 27F530T 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
