Question about Gestetner DSm755 Black and White Copier
Ricoh MP-5000SP service code sc350
Did preventive maintenance and also changed id sensor. Still giving solid black copies
4 Suggested Answers
  • 57 Answers
SOURCE: What is service code sc350 and how do I fix it?
SC 350: The most common sensor ID dirty: Clean the ID sensor
Posted on Jun 23, 2011
  • 57 Answers
SOURCE: what is service code sc350 and how do I fix it?
SC 350: The most common ID sensor dirty: Clean the ID sensor
  • 192 Answers
SOURCE: What does service code sc350 mean?
SC350:
Problem:
ID sensor pattern test error
Description:
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Problems:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
** Generally, I've found this problem to almost always be one of the last two items listed above.
Posted on Jun 25, 2011
Copies fading on Aficio 2020D even though toner is full
Hello!
First i need to know if that symptom is just in copies or also happened when you make a print.
If it is just in copy you have dirty on the exposing lamp of the scanner.
If it happened also in printing it could be several things.
I can give you same tips:
-The glass of the laser is dirty (this glass is under the tonner supply unit)
-The drum unit need to be changed.
The question is: When was the last time that you did a preventive maintenence????
Probably this is the best help i can give you; make a PM.
See you!!
Aug 04, 2011 | Ricoh Aficio 2020D Copier
Solid red light on this symbol <...> also
first change the black toner cardrige and try to run the printer most of the time the problem is gon after the change.
Apr 19, 2011 | Samsung CLP 315 Laser Printer
Changed the black cartridge now wont copy or print in black used a proper cartridge not a fake
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 10, 2011 | Office Equipment & Supplies
I have a black solid streak on my Canon D320 copies
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
Dec 01, 2009 | Canon imageCLASS D320 Digital Copier
Aficio 6513 ID sensor location / service manual
The ID sensor is located under OPC drum.Clean the optics component,the charge corona ,and see if the OPC drum is good(change every 120000 copies).
Oct 21, 2009 | Ricoh 6513 Copier
Copy machin SHARP SF-7320
Check the copy lamp and its thermal fuse if they are okay, then clean optics, check drum and blade and clean or replace and finally clean or replace fuser rollers. If the above is ok and still black copies, check the copy lamp wire harness for continuity or the copy control board located underneath the display panel and check for bad component like triac and replace. If OK replace the main control board.
Sep 21, 2009 | Sharp SF 2020 Copier
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
Copies are solid black
first try scan doucument to the pc if it is also come black then change scanner assy,
if problem is not found then replace logic card
Jul 20, 2008 | HP Photosmart C3180 All-In-One InkJet...
Black Copies
is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
http://www.retrevo.com/s/canon+7000+manual
Dec 31, 2007 | Canon LaserClass 7000 Plain Paper Fax
Gestetner DSm755 Black and White Copier Logo
64 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
