Question about JVC AM FM CD DET FACE CAR STEREO
The memory does not work after the radio is turned off
I have a model kdg333 with a 12 cd changer in the boot when the radio or ignition is turned off then turned on again the unit has no memory can you help please is it the front part of the unit or the big part in the dash thanks
    Problem Solver:
  • 4 Answers
When this happens it usually means that the ignition and battery wire are connected incorrectly. hope this helps...
Posted on Jan 03, 2009
My 03 PT radio is flaking out
Sounds like you need the anti-theft code. Usually when you change the ignition you have to put that code in
Apr 25, 2017 | 2003 Chrysler PT Cruiser
KD- R538 radio wont turn on
Make sure you are getting power to both the red and yellow wires. Red is switched or ignition and yellow is constant and controls the memory of the radio.
Feb 12, 2012 | JVC Car Audio & Video
I have a 2002 cheverolet silverado. It has a delco cd player. model 1571233. After a cd is inserted it automactically changes to the am/fm radio and an error message is displayed. It keep the cd for a...
clean the radio with a cd cleaner if dosent work replace radio call me for an estimat at 520-882-8979 most of the factory radios only work for 3 years
Jun 11, 2010 | Car Audio & Video
Hi All, I have a peugeot 206 and when I enter my four digit code into radio everything OK until I turn off ignition,then I have to input number again.Is there something else I have to do to stop this...
It looks as though the "permanent battery" feed to your radio is missing.
There are 2 battery supplies to your radio ; the main one via the ignition switch that switches the radio on/off and the permanent battery feed that supplies battery to the radio memory.
Check your fuses and connections at the rear of the radio
Apr 03, 2010 | Car Audio & Video
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Will not hold any memory when radio is turned off
There are two power wires for car radios mostly Red & Yellow check to make sure 1 wire is powered all the time in most cases its the yellow as well check the fuses from the radio on the red and yellow wire also make sure the red wire is only powered when ignition is on but it sounds like that wire is ok good luck....
Jan 03, 2009 | JVC AM FM CD DET FACE CAR STEREO
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
JVC AM FM CD DET FACE CAR STEREO Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
