Question about Cycling
The bike wobbles from side to side when exercising. Tunturi F330
Seem to me like something is amiss in holding the bike stable when exercising,
  • summernights Jan 04, 2009
    I read where this advice was free.
  • 31 Answers
Make sure the ground below is level and if it still wobbles put something underneath one side
Posted on Jul 24, 2009
Can't alter resistance on Kettler exercise bike
Looks like the resistance motor is not working , try to listen, if you can hear the motor running while switching between levels , if not than means it's either bad motor or bad wire connection
Good luck
Jan 05, 2014 | Exercise & Fitness
Purchased the Tunturi recombent bike E80R in April 2010. When I used it - it was basically a quiet machine. A few weeks ago it started making a noise when I peddled that sounds like its coming from the...
Could be that the belt is sliding against the wall of the wheel (against the ridge/lip). This is because your wheel is probably not level. This is usualy caused by wear, or because the wheel was moved or adjusted on purpose and not levelled or aligned correctly.
A 1: If your wheel is not level, the belt going around the wheel will inevitably migrate towards the edge of the wheel stand in front of the machine and look straight down at the wheel while it is motion (spinning), you should be able to see if it (the belt) is moving.
If, however your wheel is bent, this could cause the same problem. However, this is no quick fix. It will generally mean replacing the wheel
A 2: In order to recognize if your wheel is bent, stand in front of the machine and look straight down at the wheel while it is in motion. You should be able to see a, "Wobbling" in the wheel, indicating its condition.
Mar 23, 2011 | Tunturi E4R Exercise Bike Recumbent
Tunturi exercise bike stuck in high gear
Detach power cable. Remove the side panels to reveal the wheel drive's left side. Here you will see some electronic circuit - the gear engine. A small fuse (glass thing with metal in both ends) is most likely blown. Buy a new 350mA fuse at an electronics store - and your gear will be working again.
Jul 10, 2010 | Tunturi E30 Ergonomic Exercise Bike
Need a transport wheel for a Tunturi bike
Call Accell fitness they are the North American Distributor of Tunturi:
Accell Fitness North America
Phone: 1-800-667-1020
May 12, 2010 | Tunturi Exercise & Fitness
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
Mar 13, 2010 | Tunturi T30 Programmable Treadmill
No change in resistance
IF you have the one i have, there is a knob with two connected arrows and a plus and minus sign. turn toward the plus, more resistance, turn toward the minus, less resistance.
Feb 04, 2010 | Tunturi E30 Ergonomic Exercise Bike
How do I replace the battery on Tunturi E414. Thanks.
Pull the entire electronic box out of the bike housing. You'll find the battery compartment cover in the back.
Mar 08, 2009 | Tunturi E4R Exercise Bike Recumbent
Cycling Logo
214 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
