Question about Tecnik TKL9260 Front Load Washer
Need to replace lid switch to top load washer
I have discovered that the screw/bolt housing has broken on my lid switch for my top loading Kenmore washer. Thus, it hangs loose and does not operate correctly. As the screw/bolt housing is an intergal part of the lid switch assembly I will need to replace it.
To do this I will need to raise the top of my Kenmore top-load washer. Don't know how...
Model # 22892100...Type 111
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$&&(*(
Posted on Oct 01, 2010
How do we get rid of the UL code on our Kenmore Oasis Canyon Capacity Top Load Washer? It stops on the final rinse and spin cycle with nine minutes left.
Thwere is a switch under the lid that will not spin the tub, if the lid is up. This may be bent or broken. Lift lid and shine a flashlight down the slot underneath the protrusion on the lid. you should e a'plank' across the hole. No plank the swithch or the ;Plank" is broken. Most likely the plank, or actuator.needs replaced.
To replace , and or check the actuator, you have to remove the top of the machine. On a Kenmore here are 2 screws at the top back of the washer thaqt hold down 2 metal plates that go up to the back of the control panel. When the screws and plates are removed you can pry up the top of the washer with a stout screwdriver. after removing the top you can un screw the safety inlerlock, that's what I call it, and check for the bent/broken actuator or broken switch. If all looks okay then you need to take an ohm meter and check for continuity through the switch. Place one test lead at each end of the switch, removing and marking the wires on the switch. Press the actuator and you should see less than 5 ohms on the meter, if that is okay, then it gets more involved.
Let me know
Jan 17, 2011 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
My top load kenmore washer filled with water and just stopped
Try tightening the screws on the lid hinges. This should re-engage your lid switch. If it doesn't then you may need to replace the lid switch.. Hope this helps... Bill
Jun 04, 2009 | Roper RAS6233KQ Top Load Washer
Kenmore washer
depends some modles have 2 clips under the front left and right you stick your putty knife in there and pull the console up, also there could be end caps get a screw driver and pop them off then there will be 2 screws remove them. Then some models have 2 screws directly behing the consol remove them pull consol forward and up. Once you have got the consol situated there are 2 copper brakets push down and out with your screw driver this will release the cabinet soyou can replace the lid switch
Dec 26, 2008 | Kenmore 22622 Top Load Washer
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
KENMORE 80 SERIES
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. If this washer has a hidden lid switch, check the lid hinge screws and make sure they are screwed in tight.
Jun 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer
The lid switch can cause this problem. try pushing the lid toward the rear of the machine and see if it starts running. Also check the screws holding the hinge on the left side to make sure they are tight.
Oct 05, 2007 | Kenmore 22422 Top Load Washer
Tecnik TKL9260 Front Load Washer Logo
76 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
