Question about Hitachi 51SWX20B 51" Rear Projection Television
No picture We have a cable box, and we just bought new cables HDMI when hooked up there is no picture.
    Problem Solver:
  • 11 Answers
The model you mentioned does not have an HDMI input. Are you using a convertor from HDMI to DVI? If so there are several types of DVI cables/ inputs make sure you use the right one.
Posted on Jan 04, 2009
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
I bought a lg 42le4500 led/lcd tv and hooked it up to my v+ box via a hdmi lead, but picture is a bit fuzzy is there somthink i can do to sort this?
Check the setting on the V+box for a HD setting hook up should improve the picture.Still have the same problems,the HDMI cable it is the problems,changes another HDMI cable
May 10, 2011 | LG 42LE5400 42 in. LCD TV
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Dvd won't play through PACE hi def converter box, service electric cable ty
Why are you running hdmi to converter box? Run HDMI cable directly from dvd to new Panasonic plasma. The less things in between, the better the picture.
Dec 14, 2007 | Televison & Video
Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Hitachi 51SWX20B 51" Rear Projection Television Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
