Question about Kenmore Ovens
Kenmore self-clean smooth top stove C970-655821. Oven does not heat up - no heat from elements.
  • 161 Answers
SOURCE: Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Posted on Jul 15, 2008
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
How do I replace the receptacle for the heating elements on the stove top.
Typically the light is a function of the selector so as long the position of the knob is to the on position it will be on. in order for the burners to work you'll have to replace the connectors, so full current can go through them. also the self cleaning feature refers to the oven meaning you can lock it, turn it to clean and it will get so hot that the build up on the inside will get flaky and then you can clean it once it cools off. I've never seen one that work that well, but it has nothing to do with the glass there is cleaners that you can "rub" kind of like waxing a car and if you have build up on the glass or burned food you can scrape it with a razor laying flat on the glass and scrape the cleaner around will eventually it will peel off.
Jan 14, 2015 | Kenmore Ovens
New installation, does not heat
I think your ignition does not work.
Is this a brand new oven ?
Does it have a stove on top ?
does the stove work ?
Dec 28, 2007 | GE Profile JT915 Electric Single Oven
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
Kenmore self cleaning oven model 790.9520 : element stays on
sounds like it was in the preheat mode the cent to the cook mode so you can cook
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Ovens Logo
64 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
