Question about Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet
Whats error code sc 28212 - Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet
    New Friend:
Turn off printer remove carts wait 2 minutes but back in and turn on!
Posted on Feb 18, 2013
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
Ricoh sp C221SF Error code Sc 400
The board that controls it. Probably the IOB. Typically, the code is cause by a dirty ID sensor.
Oct 04, 2014 | Ricoh SP C221SF Aficio Printer
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
Ricoh SG-3110DN 28212
use a web browser and type in IP address at top and problem will be displayed
Nov 18, 2013 | Ricoh Office Equipment & Supplies
My brandnew Ricoh is saying Error SC 28212 ~ What does this mean??
Call sawgrass tech support for the reset.... it is straight forward and easy to follow. As per customer support, you will need better than 20% full cartridges, they recommend new ones, which they will provide overnight free if still warranted.(ERR28212) As discussed, here are the reset instructions.
1. Turn the printer off.
2. Open the cartridge door and leave it open until step 15.
3. Turn the printer back on.
[img id="Picture_x0020_1" alt="3110 Panel" src="file:///C:/Documents%20and%20Settings/Nancy%20Smith/Local%20Settings/Application%20Data/IM/Runtime/Message/%7B944CD05A-8C76-404B-84B9-E5D3FB8CED31%7D/Show/image0011.jpg" width="500" height="143"> (was a photo of machine front, the down button is also "menu")
4. Hold down both the Up & Down arrows together for 3 to 5 seconds (nothing on the LCD display will indicate the appropriate amount of time has passed)
5. Release the arrow buttons and press #Enter (if nothing happens, try again)
6. When successful the LCD will display SYSTEMver with 3 optional menu selections starting with Service Menu
7. Press the down arrow once to Engine Maint. and press #Enter
8. The LCD will display SP No. with the default 1000000 underneath
9. Using the Up & Down arrows, and pressing #Enter after each number, enter 3009002. Press #Enter when complete.
10. CARRIAGE CHANGE 3009002 will display on the LCD. Press #Enter.
11. CARRIAGE CHANGE EXEC will display on LCD. Press #Enter.
12. OK? will display on the LCD Press #Enter.
13. Then Running will flash on the LCD panel before going back to CARRIAGE CHANGE EXEC. Continue to next step.
14. Exit the SP mode by pressing the Escape button repeatedly until you are back at the Engine Maint. screen. Press the down arrow once to End. Press #Enter one more time to completely exit.
15. Turn the printer off.
16. Replace the four ink cartridges with new ones.
17. After the new cartridges have been installed, close the right front cover.
18. Turn the printer on.
19. Wait for the machine to fill go through an initialization procedure which may take about 7 minutes.
This 100% worked for me.... be certain that the screen displays EXACTLY what the directions tell you!! -NSmith
Aug 07, 2012 | Office Equipment & Supplies
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Ricoh Aficio Sg 3110Dn - Printer - Color - Ink-Jet Logo
431 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
