Question about Xerox Office Equipment & Supplies
Xerox 7665 won't print color
7665
4 Suggested Answers
  • 2072 Answers
SOURCE: Tab printing on Xerox 7345
There is no tabs option on the 7345. I am glad you asked that.
I was recently at school on that product, there was no mention of tab printing, I went to the Xerox.com site to inquire and tab printing is not supported.
You can call 1-800-821-2797 and inquire there. They may have an undocumented solution for tabs.
Let me know if they do please.
You will need your machine serial number when you call.
Posted on Feb 12, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
  • 33 Answers
SOURCE: Our Xerox 7665 has major
You can try the following: switch the drum to another position for example to blue (Cyan). If the defect changes to blue color problem lies in the drum.
Is the defect vertical /drum axle direction) or horizontal? If horizontal the problem is probably:
-developer assembly
-contaminated ROS (laser assy).
DO NOT EXPOSE THE DRUM ASSEMBLIES more than 5 minutes to light. Cover them with paper or black plastic bag.
Posted on Sep 15, 2010
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Have a Xerox WorkCentre 7655 showing system fault nodity system adminirattor
Notify the system administrator, unless, of course you are that individual.
Jun 12, 2013 | Xerox WorkCentre 7665 Copier
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
My Xerox Phaser 8560 is not printing the red properly. It comes out more llike a brown. The light blue comes as a teal and bubble gum pink comes out like a light pale plum. Peach comes out as beige. Is...
Solution : Print the Troubleshooting Print Quality Pages and Make Sure the Colors Are Accurate CAUTION: Use of inks other than Genuine Xerox Solid Ink may affect print quality and printer reliability. It is the only ink designed and manufactured under strict quality controls by Xerox for specific use with this printer. The Xerox Warranty, Service Agreements, and Total Satisfaction Guarantee do not cover damage, malfunction, or degradation of performance caused by use of non-Xerox supplies, or the use of Xerox supplies not specified for this printer.
To print the Troubleshooting Print Quality pages:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Problems], and then press the [OK] button to print the test pages.
  4. Go through the pages and find the Light Stripes Test page.
    For each color, remove an unused solid ink stick from the printer, and then use the ink stick to make a mark of color next to the corresponding color on the printed page. If the colors do not closely match, that color will need to be purged from the print head. Continue with step 6 if the colors do not closely match.
  5. NOTE: If the colors do closely match, the problem is not related to the printer's hardware. There is no hardware adjustment available on the Control Panel for calibrating individual colors.
  6. Create a document consisting of a full page (100% fill) of the color not printing correctly, or download and use one of the resource files provided in the table below. For example, if cyan ink is actually printing black, create a document that is a solid fill of cyan, or download and open the Cyan fill page provided in the table below.
    IMPORTANT: Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  7. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
IF THAT DOESN'T SOLVE THE PROBLEM TRY THIS: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=156,E=0000000002703198886,K=8233,Sxi=10,Solution=obj(964)
May 27, 2011 | Xerox Phaser 8560N Laser Printer
Our Xerox 7665 has major color issues... the yellow seems to be deficient but not in any consistent pattern. I changed out the color drum with no effect, and also did a color calibration, also with no...
-developer assembly
Sep 14, 2010 | Office Equipment & Supplies
When i loaded the 64 bit windows driver for the
There are more than one driver on the xerox.com site for that machine, Try a PCL driver or if you are using pcl try the PS, If you have done that, call xerox and ask for second level support and report the problem. They would most likely know by now and could offer the solution.
Sounds like a driver screw up.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox workcenter 7665 communication problem
Aug 07, 2009 | Xerox Office Equipment & Supplies
Feb 11, 2009 | Xerox Office Equipment & Supplies
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
75 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
