Question about Dell Inspiron 700m Notebook
I have a gateway laptop and the speakers built into my computer wont make a sound. ive t5riend turnung the volume up and down on and off but still nothing.
    Problem Solver:
  • 13 Answers
Gateway is good for that. have you updated ur drivers from device manager? make sure you have both a device and controller.
Posted on Oct 31, 2012
4 Suggested Answers
anuragmj
  • 40 Answers
SOURCE: Inspiron 6000 sound
Don't worry. It could be that the sound drivers are not instaled. Simply download the drivers from support.dell.com by entering the service tag. The sound should be back. The battery has nothing to do with sound. From the same website, install the BIOS update. That shoule get the battery message go away. Incase that does not happen, then you may have to buy a battery. The batteries have 1 year of warranty from the date of invoice.
I work in DELL, so please try what I ahve mentioned and you should be happy!!! If not, post a message.
Posted on Sep 17, 2008
rahulgaikwad
  • 137 Answers
SOURCE: sound problem with built-in speakers on gateway MX6025
The issue is with the audio drivers . Try to reinstall the sound drivers. Then restart the system and check.
Posted on Aug 18, 2009
  • 3940 Answers
SOURCE: My Dell 710m laptop no longer produces sound from
Yes, since I have one, I know where the likely failure point is on the system. The wires for the speakers go thru the right hinge assembly and if you remove the LCD hinge cover you'll likely find a broken wire there at the chafing point (That is where mine broke) so very careful wire splicing and a bit of shrink wrap did wonders.
Posted on Sep 30, 2009
I have a set of Logitech speakers s150 USB and Ive had them for about over a year and about a few days ago they were working fine...but now they just won turn on. usually i just unplug them and replug them...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
also try this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
hope this helps
May 17, 2011 | Logitech S150 2 Speakers
I cannot get sound on yahoo messenger pool game ive tried everything i reinstalled messenger 10 i cleared my cookies ive got the latest java and ive even tried to change profiles Ive checked my volume...
also
hope this helps
Apr 25, 2011 | Computers & Internet
I recently had to reformat my computer back to factory standards. I had the Logitech Laptop Speakers Z205 b4 this & they worked.After i reformatted now i only get volume out of my laptop built in...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Logitech Laptop Speaker Z205 2 Speakers
Hello members of Gateway, my name is Jean-Claudy, I do my best to find on the internet a sound driver for my laptop because my laptop caught a virus to another computer, I format my laptop since the ord...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
dont forget to vote
Feb 12, 2011 | Computers & Internet
Speekers on laotop wont work,the speekers on my phillips freevent x52 laptop wont work,ive tried turning the volume dials up to there full capacity ut to no avail
I have a Logitech X240 speakers, and I move so now I am trying to connect the speakers to another computer, I have it connected but there is no sound. Do I need the CD Software to be downloded?
Thank for you help.
Jan 08, 2010 | Philips Audio Players & Recorders
Sound problem with built-in speakers on gateway MX6025
Aug 18, 2009 | Dell Latitude D600 Notebook
Gateway- built-in laptop Speakers not working
Seems to me the speaker is just plain broken. You'll need a new one, contact your vendor for repairs, or you will have to live with using external speakers/earpieces...
I hope you will get your replacement,
Yannick.
May 25, 2009 | Gateway Computers & Internet
Speaker on Widows XP Compaq computer not working.
go to the control panel, go to the sound device icon,
select the audio tab, and under audio playback you should be able to change the speakers.
thanks adi
Apr 26, 2009 | HP Compaq Computer Speakers
Heat dissipation from the unit in the same area of the speaker assembly, especially since you stated that the RIGHT speaker was smoked. Similar problems occur with this design flaw with any manufacturer as HP has the same problem with some of their models.
Your heat exhaust is killing the speaker, and I would also bet that your chipset is AMD and not Intel, the latter having solved it's heat dissipationn problems.
A more aggressive heat dissipation solution on the motherboard or redirection of the exhaust past fewer heat sensitive components would be a design goal.
Mar 29, 2009 | Gateway MX6453 Notebook
Dell Inspiron 700m Notebook Logo
Alun Cox
