Question about Dirt Devil Breeze Bagged Upright
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
  • Shelley Hussman Oct 31, 2012
    No, I'm not talking about part of the brush roll, I'm talking about the actual WHEELS that are on the bottom of the vacuum. They are attached at the same spot you attach the cover plate to, and they fell off when we were re-attaching to cover plate. It was hard to get them re-attached, there is a piece that sticks out that has to go under something. Now the vacuum makes a horribly loud rattling sound, not just the sound of the motor like before.
  • Dirt Devil Master
  • 18,411 Answers
The thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Posted on Oct 31, 2012
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil M088174 Rattling Noise
You may need a new brush roll. The ends should turn easily,
Posted on Feb 22, 2008
SOURCE: M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Posted on Feb 25, 2009
ukvacfan
  • 328 Answers
SOURCE: ear piercing whistle
Its an inherent problem with any Dynammite model = the fact that the motor is at the front means that it is extremely noisy.
Posted on Nov 16, 2007
  • 1015 Answers
SOURCE: The belt broke and after putting on new belt I
Check the cylinder with brushes does not have hair or carpet fibers causing it to bind. With the belt removed the brush should turn freely and fairly easy. The original belt probably broke because of this. You may have to fully dis-assemble the head of the vacuum to clean the entire brush assembly.
Posted on Sep 19, 2009
  • 377 Answers
SOURCE: I placed the new belt on the brush roller like i
Most likely the roller is frozen due to dirt and debris. Follow the instructions to remove the belt and roller. Clean the roller as best you can and at each end where the hard rubber holders are located. Add some WD40 between the brush and these holders and turn by hand until the holders move freely around the brush. Reassemble making sure the belt is on in the correct manner so the brush rotates in the proper direction.
Posted on Oct 04, 2010
ROLLER WILL NOT MOVE
Because the brush roller is not rotating, the motor shaft is spinning in one spot on the belt and eventually will burn the belt and cause it to break. You need to remove the brush roller and its end caps to remove pet hair or other matter. You may have to replace the burned belt to get things working right again.
Sep 02, 2014 | Vacuums
My hoover fusion carpet brush wont revolve
Hello, I hope your having a good day considering your problem.
It sounds like you have done everything and more you can at your end. My opinion based on your detailed description is that is possible you might need to barrings in your roller on both ends. Now sometimes you can take it to a local vac shop (just the roller of course) and they can put the new barrings in as well as maybe it is possible that something is just loose or warn out. Sometimes you are better (for cost of repair reasons) to buy a new roller. I would first personally, take the roller off, and take in to local shop and have them give you a price to replace or repair. That appears to me what has happened. Its also possible, some dirt and debre has got trapped in where there barrings are and it is sticky or just plan stuck. Mike
Dec 02, 2011 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
The belt for the maain vaccume broke off and now with the new belt the roller will not work.
It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
Bissell Roller Brush for Lift Off Bagless
Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
How to change drive belt on bissell vacuum cleaner
Hello, you will need to take the bottom plate off, remove the screws on the plate, then pull up and out the brush roller, clean off any hair on the roller, make sure it spins freely, then put a new belt around the metal motor shaft, then around the roller and pull in down into the housing, spin the roller to make sure it moves freely, so you don't burn up the new belt, put the bottom plate back on and your ready to vacuum. Any questions feel free to call @ 1561-848-3387 I'll be gflad to help, Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Won't pick up dirt and hard to push
This sounds like it is most likely a belt issue with your Riccar. In order to verify this, turn the vacuum on and turn it over on it's side after making sure that the carpet / floor switch on the top of the roller brush housing is turned to Carpets.
When you turn the vacuum on after changing the switch to carpet mode, does the roller brush spin? The belt controls the the roller brush and makes it spin. When the belt is broken or stretched out, and the brush is not spinning, or stops as soon once it hit carpeting, the brush roller will no longer help pull the vacuum forward. This would explain why the vacuum is very hard to push.
In order to help you the best, I went ahead and took some pictures for you on how to change the belt. The only really tricky part is the clutch actuator arm. If you don't already have a new belt, here's a link for you to a 2 pack of belts for your 8955 on our website:
Riccar 4000 / 8000 Series Upright Belts (2pk)
The model that I took pictures of is actually a model 8650, but this is identical in every way to your 8955 in terms of changing the belt.
What you'll need to have handy for this repair;
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum2_bing.gif cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, this is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm from the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take a new belt and wrap it around the metal pin in the back of the vacuums agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), put the other end of the belt through your roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, as well as continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there are two little teeth that protrude out of the end cap. Here's a picture of how it looks:
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove inside of the roller brush housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right.
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Make sure that the rug / floor switch set to the carpet setting again, and then turn the vacuum upside down again so the brush and belt are exposed again.
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
tep 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as close as if the bottom plate is correctly installed. It will take away the vacuums cleaning cleaning ability dramatically. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. This is the way it will look if the bottom plate is installed the WRONG way.
Here's a picture of the RIGHT way to install the bottom plate:
The Riccar 8955 is great vacuum, and cleans better then most other upright s when it has a new belt on. I hope that this repair solution is helpful to you in fixing your vacuum. If you did, please be sure to click the Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification on the repair if you have any questions. I'm always happy to answer any questions. I hope will consider GoVacuum.com storefront for any Riccar supplies that you may need. We carry all Riccar Vacuum Bags, Filters, Belts, and Parts.
Chris J.
GoVacuum
Apr 03, 2010 | Riccar 8955 Upright Vacuum
Dirt Devil Breeze Bagged Upright Logo
180 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
