Question about Electrolux Pu3650 Central System Vacuum
Central Vacuum stopped working
System is getting power, not working and service light is on. New system have only had two months.
3 Suggested Answers
  • 13 Answers
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Posted on Oct 03, 2008
my issue was similar to solution two. It seemed to be a sticking switch attached to the power button assembly. After trying to oil it etc with no change, I eventually just disconnected the clear hose that attaches to the white pressure sensor which is on the power button assembly. Works like a charm now but I will need to be careful willmy next full bag or if I get a clog as the engine with just keep trying to ****. Much better than tossing out the vacuum if you can't find a needed switch assembly .
Posted on Oct 28, 2012
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
No suction from wall outlet. Power to powerhead. Breaker has not been tripped. Manual mode works on cannister in garage. AirVac VM458.
I had the same exact problem and it took about 4 months to find out the problem. I had a paper clip stuck to one of the orifice in the hall way of my house and that is what I had experienced. The other thing is to check the entire tube system because maybe a mouse or rat has chewed into it. It has all to do with the electrical wire throughout the system. Good Luck
Jan 06, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
On my M&S Air Vac AV425 central vaccuum system, the system usually turns on by inserting the vaccuum hose into one of the vaccuum outlets. However, it now runs continuously. I am able to turn it off...
we are a central vacuum service company and we service all of new jersey. sounds like you have a short some where that keeps your unit running or it could be your relay module thats stuck our number is 908-721-7595 its j&j central vacuum services
Dec 28, 2010 | Vacuums
Nutone central vacuum leaks brown liquid
Dear lord, that is the most absurd thing I've ever heard. Who installed the Vac and DW or were they both in the home before your time?
Normally, if liquid drips out of a CV outlet it's because it was sucked up during vacuuming. However, if your vacuum runs or has suction at the outlets due to the dishwasher running, you have a low voltage gap being bridged by either the dishwasher's wiring or by liquid leaking from it onto the CV wiring somewhere.
Bottom line, you have MAJOR issues inside your home with one or both of the systems, and if there's liquid, there's a dishwasher to be worried about! Look below it for leaks into the basement/lower floor; follow the plumbing (especially the drain waste runs) and figure out where the damage is before your house suffers the lot.
Jul 12, 2009 | Broan-NuTone Vacuums
Replacement of cv-350 model motor and does not vacuum, brown out. i switched black and white codes but same thing. Please help me.
I contacted to MD service technician. He explain, good advise. I follow his directions and cv350 works very good. Power getting as new. Thank you very much.
Jun 25, 2009 | Broan-NuTone CV350 Performance Bagged...
Eureka central vac 's power stopped won't start again.
I took to dealer I bought from . He examined it. The motor is gone needs new one. Thanks, Ann
Jan 24, 2009 | Eureka 1810 Central System Vacuum
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Electrolux Pu3650 Central System Vacuum Logo
53 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
