Honeywell Programmable Thermostat 5-1-1 Day RTH7400D user manual
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
SOURCE: switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Posted on Jul 27, 2009
SOURCE: Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Posted on Aug 14, 2009
billyvangogh
  • 108 Answers
SOURCE: need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Posted on Oct 26, 2009
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Need manual for Honeywell thermostat ct3500
Here you go Carol.
Honeywell CT3500 Owner Manual
Have a great day!
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 20, 2014 | Honeywell CT3500 5-1-1 Day Electronic...
Manual honeywell programmable thermostat
Follow the below link, select thermostat on the upper box, then type CT3600 on the lower box.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Oct 09, 2012 | Honeywell CT3600 7 Day Electronic...
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
My Honeywell Programmable Thermostat RTH2410 operates intermittently, the entire unit , display and all, turns on and off at various times throughout the day.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You need to reset the t-stat and totally reprogram it...
Look in your manual how to do that or...
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 13, 2010 | Honeywell Focus 6300B 5-2 Days...
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Oct 18, 2009 | Honeywell Electronic Programmable...
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
Dec 28, 2008 | Honeywell Electronic Programmable...
Switching thermostat from farenheit to celsius
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
