Question about Bosch Drills
36v charger my charger flashes green clicks then flashes red and then green and so on
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: when put on charge the green and red light flash
that usually indicates a bad battery. I would unplug the charger for a couple minutes to reset it and then try again before looking at replacing the battery. Most shops have a tester there that can tell if it is in fact bad.
Posted on Jan 23, 2010
rowdy45176
  • 2176 Answers
SOURCE: where to buy a hilti 36v ni-cd battery and charger
call them direct at 1-800-879-8000 and they can find you a dealer close to your area or you can buy direct.
Posted on Apr 25, 2010
  • 177 Answers
SOURCE: where can i get my hilti 36v charger repaired
Most chargers have a replaceable fuse. This may have blown.
Posted on Jul 17, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
I am in Canada and I cannot get a Black & Decker 36V charger which is LCS36. The B & D 36V battery looks identical to the Dewalt 36V battery but I cannot be positive. Do you know if the B & D LBXR36...
What I do know is that some NiCd 12V Black decker batteries that look similar to the dewalt ones they are charged by the dewalt charger.
But there are 12V Nicd black and decker batteries that they can not be charged due to an extra plastic edge that does not allow to be charged by the dewalt charger.
Now if you do have the dewalt lithium 36V charger and if the black and decker battery is a 36V lithium one and can not be charged due to a plastic edge then I would recommend to risk to destroy the plastic edge in order the black and decker battery to be charged.
Sep 25, 2013 | Dewalt Black & Decker / DC9360 36V Battery
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
My charger blinks red and green but I've literally only used my chainsaw 4 times. It's less than a year old. It won't charge the battery. What could be the issue? Or can I take it back to home Depot and use the warranty? Any help will be welcome.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
I have a 36v ac 3640 cv charger with a burnt out thermistor i need to know rating for the thrmistor marked up on pcb as r2
hi mate i know its 2 years over later if u have red flashing led this normally fixes fault..replace R2 ON CHARGER,
www.uk.farnel.com then search this,,,:- B57236S500M
Mar 09, 2011 | Bosch Drills
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Drills Logo
62 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
