Question about GE Washing Machines
Problem with Kenmore washer combo 110.88762793 and water leaking
Need to know if front comes off washer also.
SOURCE: WATER LEAKING FROM FRONT BOTTOM
Check your door boot, ours is doing the same thing. Found out there's a huge hole in the door boot seal.
Posted on May 29, 2008
jsrock516
  • 5911 Answers
SOURCE: Front Loader Kenmore Mod # 110.44832202 is leaking.
The rubber seal is known as a bellow. If the bellow is torn, more than likely it IS the cause of your leak. Your only course of action is the replace it. Searspartsdirect.com carries replacements. Just type in your model (as you provided) and look under the "Door and Latch Parts" heading for item number 1 (part #8182119). It is not a cheap part, but it will cost you much more to have an appliance repair company install it for you. This is not a difficult repair, and you can accomplish this on your own if you follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Some additional parts that normally do not need replaced, but you may consider just in case are the front and back clamps that hold the bellow in place. They are listed under the same heading as items 6 and 14. They don't cost that much and may consider them just in case you need them. In particular, the front clamp, can break or the spring becomes stretched. Inspect these items just to be sure.
I hope you find this information helpful. If you require additional assistance, please let me know.
PS You may also try repairclinic.com for comparative pricing. They also carry the same parts (sometimes for less).
Posted on Sep 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washer/Dryer Combo Model # 11088752792
The problem is usually attrbuted to leak-by on your Water Inlet Valve (also known as a "Mixing Valve" on some models). The valve can become clogged or corroded with rust and sediment over time and not seal completely when shut off. This is especially true if you live in areas where you have hard water, or use well water. If the diaphragm inside the valve does not seat correctly, this will cause leak by. It may be very minute, but will become noticeable over a period of time. The washer does not have to be turned on for this to occur. You can try to remove the valve and clean it thoroughly to see if this will help, but if you are going to to go the route of removing the valve, it would make better sense to simply replace it instead of having to possibly go through the process twice. A replacement valve can be found at searspartsdirect.com. Just type in your model number and look under the "Washer Cabinet" heading for item number 5 (part #285805). This is a fairly simple repair that is also inexpensive. To replace:
1. UNPLUG the appliance and shut off the water at the water taps.
2. Disconnect the fill hoses from the back of the washer.
3. Remove the panel directly above the washer top.
4. Remove the washer top panel.
5. The fill valve will be located in the left rear (as viewed from the front) behind the wash tub.
6. Remove the dispenser hose and electrical connectors from the water inlet valve.
7. Remove the mounting screws that hold the valve to the rear panel.
8. Reinstall new valve using the above steps in reverse order.
The repair is pretty straight forward. If you have questions, please let me know. I hope this helps you.
PS In the interim, to keep the tub from filling up with water, shut of the taps when not in use. This may buy you some time until you are able to replace the valve.
Posted on Oct 25, 2008
  • 530 Answers
SOURCE: Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Posted on Mar 26, 2009
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
I Have a combo kenmore washer/dryer model # 417.94712400 and I need to open the washer to inspect a water leak. how do I open this washing mashine.
Remove the 2 screws at the base first
If ya run a load with the front off to look for leaks remember there are moving parts
I recently worked on a dryer portion and took these photos
Jul 25, 2011 | Washing Machines
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Kenmore 70 series is leaking water. Could it be the pump?
It depends on WHERE the leak is coming from. If the leak is coming from the FRONT area of the washer, the drain pump or drain hoses are suspect. If the leak is coming from the REAR of the washer, the water inlet hoses, water inlet valve, or dispenser hoses may be suspect. If the leak is coming from under the CENTER portion of the wash tub, the tub seal or wash tub may be suspect.
The first step is to remove the exterior washer case to gain access to view. The following link explains how to replace a water pump (if required) on your washer, but also includes all the steps necessary to access the washer interior:
http://www.fixya.com/support/r397092-replacing_water_pump
Allow the washer to fill about 1/3 of the way and turn it off before unplugging and removing the washer casing. The washer will not run once you disconnect the lid switch connector, so you will need some water in the tub to see where the leak may be coming from.
NOTE: If the problem IS a leaking pump, these pumps are not serviceable and will need to replaced.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
May 31, 2009 | Washing Machines
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Water leaking when washer is filling
  • Is the water coming from the front center?
  • if it is it is coming from the water pump.
  • just let me know which side and how fast it is flowing
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
