Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Frost on bottom of freezer inside refrigerator section, leaking
Greetings.  I have a Kitchen Aid fridge with freezer on top.  the bottom of the freezer section, inside the fridge part is icing and then melting and dripping inside the fridge.  I've tried different freezer settings, but it doesn't seem to help... and I'm confused by the dials.  one side says colder, the other warmer, but I don't understand if it's the high number or the low number that corresponds to cold or warm.  What should I do? thank you for your help!
  • turtlewolf3 Jan 05, 2009
    THANK YOU!!!!
  • Anonymous Jan 29, 2009
    I need to know what number setting is colder and what is warmer for the freezer?
  • 163 Answers
Hi!!! You have a plugged drain line in your evaporator..For a quick fix just turn off your frig for 24 hours and set your temp control at the factory setting listed on the frig and you will be finw trust me..Good luck..
Posted on Jan 03, 2009
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
I have a Kitchen Aid refridgerator. My freezer
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Jenn-Air JCB2280HES Side by Side...
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
DRIPPING SOUND MAYBE POPPING ALMOST
This is normal operation, every 8 to 10 hours the heater in your freezer section turns on to defrost ice and frost from evaporator coil, this melting water hitting the heater is what is making popping and hissing noises.
Jan 20, 2009 | KitchenAid KTRS19KMSS Top Freezer...
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
170 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
