check the clutch start switch or the park neutral switch operations
you need the clutch in to start and there wia switch there that may need adjustment
same for the auto park /neutral switches
check wires
leave it plugged in for a few hours and see how it goes im talking like 4 hours... if still nothing then it could be the fuse on the main power board.... hope this is helpful :)
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Not all replacement parts are good. I would guess that the new ignition switch is bad. Its also possible that the wiring harness is loose where its connected to the ignition switch. You could try jiggling the wires.
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
same here! first my original car charger stopped working, so i purchased a replacement (a generic one off ebay), plugged it in and the little light on the top right turns on. but i have not been able to turn it on. i've left it charging for at least a half hour and nothing. any ideas?
