Have audio but no picture 51pp9303 replaced convergence chips and still same problem
  • tracy c Nov 02, 2012
    The picture was starting to warp and finally went out, I replaced the convergence chips which many recommended but stilla hve the same problem.
    still have*
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Check all the low value resistors that are 1/2 watt around the chips--look for any slightly discolored-----most will be between 1.8 ohms and 5.6 ohms---often a bad chip will take one out---protection
Posted on Nov 02, 2012
5 Suggested Answers
  • 8457 Answers
SOURCE: Replaced IC chips, but can't fine-tune convergence.
U know how to use a multimeter right?Check and replaced all the resistors near the 2 convergence ICS.Most resistors are big and blue core in colors.
Posted on Feb 15, 2010
  • 30 Answers
SOURCE: Convergence issue, replaced convergence chips, now blinking red power light and no picture
Recheck all of your solder connections for bridging and cold solder joints. Check the large output resistors under the heat sink and the smaller ones to the left of them. Check all of the fuses on the power board. And make sure that you check all of your connectors carefully. Also check that you didn't pinch a wire somewhere.
I am not being mean by saying that if you could power up before then more than likely the power up issue was caused by something you did.
Posted on Mar 02, 2010
Ecollier2012
  • 3459 Answers
SOURCE: No picture after replacing convergence ICs on TN50x81
You likely have shorted soldering. If you bought a kit from someone go back to their site and ask for help.
Posted on Mar 25, 2010
  • 597 Answers
SOURCE: how do i replace my convergance chip
contact parts distributors who sell convergence kits for your model.
Order instruction DVD.
Posted on Jun 03, 2010
Hear chirping sound from power switch, keeps tying to turn on, but no picture.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
How do you fix the convergence on a big screen television? R52WH77 Picture showing red, blue, and green lines on top of the screen.
Projection TV sets have two very common problems oulined below.
  • Screen looks 3D
Dec 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a WD 65831 Mitsubishi television. I love it and have had NO problems so far with it. The picture and letters on the screen seem slightly fuzzy (out of focus). I had the bulb burn out and I replaced...
  • Screen looks 3D
Dec 24, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
I can barely see the picture
  • Screen looks 3D
Dec 23, 2010 | Philips Magnavox 51MP392H Rear Projection...
How do i replace my convergance chip
Jun 03, 2010 | Televison & Video
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
"convergence chip failure"
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Oct 05, 2009 | Sony KP-43T70 43" Rear Projection...
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Philips tv
Sounds like your convergence chips are shorted which would make the set shut down. Its also possible that the flyback has failed but because the first symptom was the 3d look I would start with the convergence repair.
Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
No audio or video - typicaly occurs after having the distorted color problems listed above.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 29, 2008 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
