Where can I find a GTD Audio G787L UHF Diversity Wireless Microphone manual
  • 48 Answers
SOURCE: what setting do i use to run my cordles mic in to audio 1
Without more clarification I am assuming that you have the onboard mic plugged in normally & I don't know where the RF mic is connected.
First thing is that we know that you get sound from the shotgun mic in ch. 1. If you do not plan on using the onboard shotgun, then the fix is easy! Since it has been confirmed that ch. 1 works, just disconnect your shotgun & plug in the RF receiver to that, check your levels, and shoot away.
If you are still wanting to use that shotgun along with the RF, then I suggest that you re-read pages 51 - 54 of the instruction manual. You can find where to jack in, how to set, and change audio levels on these pages. Good Luck!
Posted on Jun 17, 2009
SOURCE: I bought a samson se50 headset microphone to go
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Posted on Jul 22, 2011
technical114
  • 1851 Answers
SOURCE: can anyone please tell me
Shure SM58 is not a wireless microphone, so clarify me the exact model for your wireless device in order to help you.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 06, 2011
diodeic
  • 1622 Answers
SOURCE: Anchor 16 channel UHF wireless.
Disable muting if you do not hear any signal from the microphone. Even if the transmitter unit is powered on, if muted it will not send any audio signals to the wireless receiver. Right next to the word "mute" there is an arrow pointing to the left; move the switch away from the direction of the arrow to turn off the muting feature and check the microphone again to see if it transmits any signals.
Replace the batteries in the transmitter unit if you still do not hear a signal after ensuring that the transmitter is not muted. The transmitter fits a standard AAA battery in the battery compartment. The battery compartment cover can be removed by hand by applying gentle pressure to the logo on the transmitter unit.
Remove or power down any audio and/or video equipment near the transmitter or receiver that may cause interference. The wireless microphone system operates on RF frequencies, so any equipment installed near the transmitter or receiver that uses RF frequencies (such as RF remote controls or wireless speaker systems) could cause audible humming, buzzing or popping while you are using the microphone. Temporarily turn off the devices or remove them for testing purposes and check the microphone again to see if the signal is clearer. If it is, place either the interfering equipment or the system in a location so that RF interference is no longer an issue.
Hoping this will help in solving he problem....
Posted on Sep 19, 2011
  • 7 Answers
"shure marcad diversity type" With this hint, I gather you trying to use the wireless system. It's quite simple....Ensure the mute switch on the mic is NOT on. Ensure 9volt battery is good and the contacts on the mic is not dirty or corroded. Unscrew the battery cover and check that the frequency on the label is the same as the label on the back of the receiver. If it is not the same then the mismatch will prevent it from working. Before checking the actual output of the receiver to the amp is working, check the mic output is reading on the level lights of the receiver as you speak. This can also tell if the mic is actually putting out a matched frequency with the receiver or if working at all.
Posted on Feb 28, 2013
How to connect 5810 with Pioneer A-20-K Amplifier
Impossible because there isn't MIC IN on the amplifier.You may use small mixer to connect the mic.there and connect the mixer in AUX IN on Your amplifier
Mar 08, 2013 | TOA WT5810-16 Channel Space Diversity...
Can anyone please tell me how to use a shure sm58 radio antenna wireless microphone or manual as ive just purchased this of ebay and no instructions came with it so a little lost as no sound coming from...
Thanks and regards
Stelios
Sep 06, 2011 | Shure SM58 Professional Microphone
How do I reset the channel and group on my SHURE SM58?
The easiest way to change the microphone is to sync it to the receiver.
Jun 03, 2011 | Shure SLX Series Wireless Microphone...
Porque en la pantalla pequeña de la
actualisar you have your camera software can be hopefully help with virus
Dec 05, 2010 | Telex ENG100LA Camera Mountable UHF...
My shure receiver is stuck on channel 3 and it doesn't let me pair it with my transmiter, why is it doing that?
I suggest calling Shure. They can assist you with troubleshooting. Call 847-600-8440. Make certain you have the wireless system with you so that they can walk you through some possible solutions.
Sep 20, 2010 | Shure PGX-4 UHF Diversity Wireless...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
I have 2 PGX-4 sm58 systems and 1 PGX-14 guitar system, problem is sometimes the mics make a load honking noise? I have returned the mics once and got new ones, same thing still happens. Not all the time...
If its feedback that is the problem, Try moving the speaker stacks forward. You shouldn't be ahead of an imaginary line drawn from one stack to the other. Another thing to do is; if you have a graphic EQ with peak lights on each slider, try dialing that frequency down a bit to remove the feedback. If you are relying on the sound from your mains to here yourself, you should invest in at least one monitor cab for the people using the mikes. Hope this helps.
Oct 20, 2009 | Shure PGX-4 UHF Diversity Wireless...
Akg sr40 wireless microphone
take your broken aerial and go to (radio shack)near you and buy a similar one and fix it in your system with screwdriver.
Apr 05, 2008 | AKG SR40 Diversity - UHF Receiver...
Buzzing noize
Have you tried using a different power adaptor? I have noticed with mine that the as the original failed there was a noticeable hum, a new power supply (of reasonable quality) solved the problem.
Feb 15, 2007 | ElectroVoice RE-1 UHF Wireless Handheld...
525 people viewed this question
 Grubhead
Grubhead
